Results 1 to 13 of 13
Thread: wireless network gurus enter:
06-03-2009, 02:52 PM #1
so i'm trying to use my i760 verizon ppc phone with my existing wireless g network because my cell signal is really slow inside the house (bad area anyway for cell signal) but i cant get the damn thing to connect! both my laptops connect fine and even my pc has a built in wireless and even it connects fine. it has to do with the security settings because i can find the network and the ssid/channel are correct, as is the detected security (wep) but i get an incorrect key prompt on the pda while trying to connect.
its a linksys g router and its set up to not broadcast the ssid (so i selected "hidden network" on the pda and type it in manually so it can find it, which it does). the secutity mode on the router is set to wep, transmit key 1, wep encription 64 bit 10 hex digits, i have a passphrase and 4 automatically generated keys.
on the pda it doesnt ask the wep encription part, nor a passphrase, but lets you type in a manual key. i unselected "key is automatically provided." ive tried all 4 codes my router generated AND the passcode and none work. what am i missing? if i disable all security on the network it connects fine so i doubt its a hardware error on the phone/pda part, but im not gunna run without security!
06-05-2009, 07:52 AM #2
I use bluetooth to connect my "Q" inside my house...
06-06-2009, 05:39 AM #3
Are both set for "OPEN" or "SHARED" key authentication?
If both are not the same, even though the key is correct, they won't talk.
06-06-2009, 05:04 PM #4
well my router has a mode where it can accept open or wep, or just wep, and any combination on both the pda and router yield the same results... "network key incorrect"
06-07-2009, 06:43 AM #5
Open everything up to verify that you can connect. Then lock it down.
06-15-2009, 09:53 AM #6
06-15-2009, 09:54 AM #7King 0f n00bz
- Jan 2006
- Shepherd, Michigan
i would love a update on this
06-15-2009, 09:56 AM #8King 0f n00bz
- Jan 2006
what is this 4 codes things your talking about on your router...??
1. wep is pointless...if your router and phone support it..go wpa or wpa2 personal.
2. if you can control it..turn off the random code thingy..just go straight key
06-19-2009, 04:47 AM #9
06-19-2009, 04:49 AM #10King 0f n00bz
- Jan 2006
we have consistently seen a drop in performance and connectivity at our on campus apartments when the clients have a large amount of bluetooth devices..along with 2.4gh cordless phones.....1 BT device obviously wont hurt performance etc greatly..but if a ps3 and a bunch of other blue tooth devices are active in his room/house/apartment then yea it will suffer
06-19-2009, 04:49 AM #11
06-19-2009, 04:51 AM #12
06-19-2009, 04:52 AM #13
It's true that a large amount of Bluetooth, Cordless, and Wifi devices all in a small area (such as a college campus or office) can cause interference. However, in a normal household, there just isn't enough "stuff" to make an impact. Recent versions of the 802.11 and Bluetooth specs have "frequency hopping" to avoid bumping into each others' signals.
photoshop wtf? gurus enter:
By grandkodiak in forum Computers / GamingReplies: 4Last Post: 06-29-2009, 07:44 PM -
Family Guy Gurus please enter
By OreoLt1 in forum Almost Anything GoesReplies: 15Last Post: 07-22-2008, 06:20 PM -
Wireless networking gurus enter
By grandkodiak in forum Almost Anything GoesReplies: 3Last Post: 07-17-2007, 11:10 AM -
Pirate gurus enter
By grandkodiak in forum Almost Anything GoesReplies: 20Last Post: 03-21-2007, 02:20 PM -
Computer gurus enter help :(
By grandkodiak in forum Almost Anything GoesReplies: 7Last Post: 08-28-2006, 08:15 PM
