Results 1 to 20 of 21
    - = LR = - grandkodiak's Avatar
    x
    Pirate gurus enter
    I would like to "backup" one of my dvd's from my collection "incase" something happens to it... what software do i use to go about this? i have nero, alcohol 120 but they both give me the "copywrited" bs thing.
    Impounded eddierox's Avatar
    alabama
    2004 Z06
    Have you tried copying the entire DVD to an external Hardrive?
    Try DVD Decrypter I use it to back-up all my DVD collection.
    I use this coupled with dual layer blanks to create exact copies with nothing left out.
    alabama
    2004 Z06
    I'm using Windows Vista now and I noticed that I when I backup DVD's, it will do so easily without any kind of warning.
    However it stops backing up the Windows Vista OS (only on DVD) because it stops backing up a particular file on the DVD.
    So I'm trying to figure that one out.
    x
    lol thats because its sending your info to hq and if it gave you the option to back out theyd lose the trial
    Quote Originally Posted by eddierox View Post
    @Eddie ~ how are you liking the Vista os? I am contemplating upgradeing to Ultimate but everything I hear/read/research says to wait.
    You are the only one I know (evil twin) that has any experience at all.
    Maybe you will have to have enother Cpu tip of the day regarding Vista os when you get all the bugs worked out?!?
    alabama
    2004 Z06
    Well I have a crack now and I'm dying to try it out on my new Seagate 150/300 16mb buffer SATA when it gets here ....
    alabama
    2004 Z06
    I'm pretty good with the Vista now and I recommend that you go for it.
    You can wait to see if they do anything new with it, but I imagine it will be in the form of Service Packs.
    My only complaint thus far is no Hardware monitoring and Coolbits type of regedit for the Nvidia overclock.
    But you see everything is nice and worked out in Vista so everything seems Overclocked.
    My opinion thus far is that you really need to have the fastest hardware you can get and Vista is to XP as it was to 2000/98.
    x
    ok DVD Decrypter seemed to do whatever it did... but it made a bunch of files, what am i suppoed to do with those? none of them are image files, do i just write them stright up to a dvd now?
    You have to select the right write and then read type from the file menu. I believe it is .iso format. It copies the entire disk to your HD encyption free and has a .mds file that you click on when you switch to write mode. I know I had to change this setting as the one I use is not the default.
    I am at work atm but I will check which format I use for you.
    PM me to remind me if this thread dies...
    Ok I am at home and you have to select mod-ISO-Read (then Write) from the top menu bar.
    Read it first then writte to a DVD-DL blank!
    x
    got it! unfortunatly i dont have a double layer!! only the cheap as 4.7gbs that were on sale lol.
    is there anyway to burn it to 2 dvds instead of dual layer?
    alabama
    2004 Z06
    Quote Originally Posted by grandkodiak View Post
    You should get a little pop-up that says enter disk 2 ..
    if it says not enough disk space on disk ... see if you can access each part of the programming on the DVD (in media player) and burn to the near maximum for the disk
    x
    i got a popup but it said disc did not have enough space, please insert one that does... it doesnt even get to the burning stage, guess it does a check before it even begins?
    alabama
    2004 Z06
    Yes it does so you will have to open the DVD in Windows Media Player and open the sidebar to the right and check the properties of each episode of the DVD.
    Calculate how may episodes will fill a disk.
    This is assuming you can burn each episode.
    However my opinion on the matter is to buy a dual layer DVD RW to compliment your DVD player.
    Member tpilews's Avatar
    Tampa, FL
    '98 Z28
    You should just use DVDShrink to get rid of all the menus and bullshit you don't need. Most movies I backup, I don't need a DL dvd.
    Quote Originally Posted by tpilews View Post
    Yes if you want only the movie itself this works most of the time. (unless it is an epic or even 2 hours in length)
    Tampa, FL
    '98 Z28
    That is true. However, even if you have to compress the video quality a little bit, you probably won't be even able to notice a difference unless you are watching on a +70" screen.
    But, yes, you should use a DL DVD for movies longer than 2 hours, for the most part.
    x
    110" baby
    Then you better man up and buy the duel layer blanks bro!
  1. Presentation Gurus Enter
    By 35th-ANV-SS in forum Almost Anything Goes
    Last Post: 01-25-2013, 10:35 AM
  2. photoshop wtf? gurus enter:
    By grandkodiak in forum Computers / Gaming
    Last Post: 06-29-2009, 07:44 PM
  3. Family Guy Gurus please enter
    By OreoLt1 in forum Almost Anything Goes
    Last Post: 07-22-2008, 06:20 PM
  4. Wireless networking gurus enter
    Last Post: 07-17-2007, 11:10 AM
  5. Computer gurus enter help :(
    Last Post: 08-28-2006, 08:15 PM
