Results 1 to 20 of 48
Thread: Speed limiter
06-02-2009, 07:07 AM #1Junior Member
- May 2009
- Western NY
Dark Metallic Blue- 2000 Z28
Speed limiter
So I have had my car for about a week now and just took it fast enough to find out how fast it wont go.. What needs to be done to get the "125 mph" limiter disabled?
06-02-2009, 08:28 AM #2Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Light Pewter Metallic- y2k 8-cylinder catfish
You have a speed governor on your car? Did it not come with Z-rated tires? I would say to delete the governor, you'd need to use a program to remove it from the computer.
06-02-2009, 09:12 AM #3Junior Member
- May 2009
- Western NY
When I hit just about 125, the pull halts. It sucks, I hate it.. The car came with Hankook Ventus RS2's on it.. Obviously not stock tires...
06-02-2009, 09:17 AM #4Senior Member
- Mar 2007
- Henryetta/Tulsa Oklahoma
I've never known our cars to be speed governed
I know my car was bone stock when I got it, except for a K&N filter, and I have pegged the speedometer once, and been upwards of 135 a few times no problem...
But if it is, you'll need at least a handheld tuner to turn it off, or send your PCM to Frost and he'll do that and tune it for you for a real good price
06-02-2009, 09:29 AM #5Junior Member
- May 2009
- Western NY
ECU tune on an unmodified car? What are the pro's and con's(if any), and what does it cost?
06-02-2009, 09:33 AM #6Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Then your car didn't come with Z-rated tires from the factory and it has a speed governor programmed into it. That would be the only reason the LS1 cars would be governed. The first years of the LT1 f-bodies had speed governors on both non z-rated releases and on all convertible models.
Luckily, my first Camaro ('94 Z28) came from the factory with the Goodyear Eagle GS-C tires, which were z-rated. The z-rated tires that came on LS1 Z28's were the Goodyear Eagle RS-As.
06-02-2009, 09:34 AM #7
06-02-2009, 09:36 AM #8
06-02-2009, 12:49 PM #9Exalted Cyclops
- Feb 2007
- San Diego, CA
If your car came with the V rated 235-16's as stock then it would be limited in how fast it can go. If so then I'll bet it also came with 2.73 gears.
And my 96 Z28 vert was top speed limited to 118mph even though it had Z rated tires.
06-02-2009, 12:51 PM #10
06-02-2009, 03:11 PM #11
06-02-2009, 03:16 PM #12
06-03-2009, 04:15 AM #13Junior Member
- May 2009
- Western NY
My door jam sticker says 245/50/r16
06-03-2009, 06:41 AM #14
06-03-2009, 10:21 AM #15
Are you sure it's not a V6 lol, my car never came with a governor and i've reached 135 before shutting it down............
06-03-2009, 10:48 AM #16
06-03-2009, 11:08 AM #17Member
- Sep 2005
- south, GA
Silver- 00 Formula Firehawk
06-03-2009, 11:15 AM #18
06-03-2009, 12:24 PM #19Member
- Sep 2005
- south, GA
06-03-2009, 12:30 PM #20Consumer of kraut
- Dec 2006
- Jenks/Tulsa
No, I'm not the original owner of the car. But before this one, I had two other LS1 Z28s that both came with RSA tires and they weren't governed either. The first one was a new but dealer driven car and the second was brand new. I don't believe the RSAs were Z-rated tires (I have an old set of two in the garage, so I'll look later) but the cars weren't governed either. My first Camaro, a '94 LT1, was the only one I've had that came with the GS-Cs.
Question: gov/speed limiter
By william SS in forum Computer & TuningReplies: 1Last Post: 01-10-2012, 06:54 AM -
Rev limiter
By konigandy6 in forum CorvetteReplies: 4Last Post: 03-12-2010, 04:58 AM -
speed limiter?
By slpdablueZ28 in forum General HelpReplies: 18Last Post: 11-07-2008, 08:30 PM -
z28 Speed Limiter?
By mst219 in forum Camaro / SSReplies: 6Last Post: 12-18-2006, 06:40 PM -
Removing Top Speed Limiter
By Krazy351w in forum V6Replies: 4Last Post: 11-25-2006, 09:01 PM
