Results 1 to 19 of 19
Thread: speed limiter?
11-06-2008, 07:31 PM #1
speed limiter?
is there a such thing as a factory speed limiter installed in our cars? cause i heard that on some american cars they shut off after a certain speed. i think a similar thing is a rev limiter on european cars sold hear? or so i heard
11-06-2008, 09:39 PM #2
My 99 Z28 came with a speed limiter of 160mph from the facotry.
11-06-2008, 10:14 PM #3
my old 90 z24 cut out at 115 mph then wouldn't kick back in till it dropped down to 105 mph
11-06-2008, 11:48 PM #4Nuclear Cat Will End All
- Apr 2007
- Edwardsville, IL (So. IL Univ. of Edwardsville)
Mystic Teal- 1999 Camaro Z28 - A4
Cars that came with Z rated tires didn't have one... I think it just shut the fuel supply off when you reached a certain RPM in your final gear.
Cars without the Z rated tires (V6's and some Z28s) had a limiter... Not sure on the exact speed... But I think it's around 115?
11-07-2008, 12:11 AM #5Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Check out this thread:
http://www.ls1.com/forums/showthread.php?t=99818
11-07-2008, 12:17 AM #6
I'm pretty sure all newer cars come with factory rev limiters. most of the small 4banger imports don't need a top speed limiter because their lower power output makes them hit a (brickwall) as far as top speed. (resistance works as the limiter) but most of the larger displacement/ hi output imports still run topspeed limiters
ls1powerhouse is right the "rev limiter" for us is a rpm set fuel cutoff
11-07-2008, 04:46 AM #7O U 8 1 2
- Nov 1999
- over here...
yes... they are speed limited through the PCM... i believe the cut off is 162mph...
11-07-2008, 05:41 AM #8Junior Member
- Nov 2008
- taylor,mi
white- 98 trans am
there are both speed limiter stops your car at a certain speed. most sports cars are around 140 to 165 trans am , vettes, camaro, etc....
rev limiter stops your rpms at a certain range so you dont hurt the motor or warranty issues such as stock our trans ams stop at 6 grand but with a tuner or tune i have mine at 6600 and thats mild could do more
11-07-2008, 06:03 AM #9
11-07-2008, 06:21 AM #10Junior Member
- Nov 2008
- taylor,mi
white- 98 trans am
i set mine from my handheld. at the track i use very aggressive 6600. for street and everywhere else i keep around 6200 unless taking a race but thanks
11-07-2008, 06:30 AM #11
ok cause ive taken it up to 125 but didnt really know how high i could go before it would kick in. so im basically good till around 160? is there any problems to the car if it kicks in? or it just causes u to slow down and the car starts working again normally?
2002 z28-slp cai, slp loudmouth, slp tuned headers, slp 85 mm MAF, slp high flow cats, 3" y-pipe and collectors
331.6 rwhp/356.9 rwtq
11-07-2008, 06:36 AM #12Junior Member
- Nov 2008
- taylor,mi
white- 98 trans am
oh you will be able to tell when both the rev limiter and the speed limiter kicks in. you have a z28 so i dont think it kicks in till about 155 or 160. so i think you will be good. all it will do if you do get there is you will feel you car jerk a little bit for you to know to let you foot off the pedal it wont let you pass that speed unless you get a handheld or tune to stop all limiters
11-07-2008, 09:13 AM #13
word, thanks for the info guys
11-07-2008, 10:06 AM #14
No, convertibles have a low cutoff; like 112, most everything else is 160.
Don't confuse RPM based rev limiters with the speed limiter; they are different as well.
To the poster spinning his stock sprung setup to 6600; not only is that WAY past your power band, but you are in serious engine jeopardy territory. As noted; stock springs float very low; much lower than 6600.
11-07-2008, 10:19 AM #15O U 8 1 2
- Nov 1999
- over here...
with the acception of my LS6...
i can rev a bit higher...
11-07-2008, 12:14 PM #16Bat Outta Hell
- Jul 2007
- Southeast Texas
Black- 96 Z28Ttops, 98 Z28 Conv.
Yeh ive got my 98 up to around 152 and let off, was at around 6100rpm ( A4 )
11-07-2008, 02:14 PM #17
11-07-2008, 02:29 PM #18the cake is a lie
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
thats what Ive heard also the cars that came with z rated tires were set at 160 and non z rated tires set at 115. not all z28s came with z rated tires. all ss models did tough
11-07-2008, 08:30 PM #19
Question: gov/speed limiter
By william SS in forum Computer & TuningReplies: 1Last Post: 01-10-2012, 06:54 AM -
Rev limiter
By konigandy6 in forum CorvetteReplies: 4Last Post: 03-12-2010, 04:58 AM -
Speed limiter
By 2k_Zed28 in forum General HelpReplies: 47Last Post: 06-20-2009, 03:29 PM -
z28 Speed Limiter?
By mst219 in forum Camaro / SSReplies: 6Last Post: 12-18-2006, 06:40 PM -
Removing Top Speed Limiter
By Krazy351w in forum V6Replies: 4Last Post: 11-25-2006, 09:01 PM
