    CT
    2001 camaro Z28
    Loose steering wheel
    hey, the steering wheel on my camaro moves down to the left if i pull on it. does anybody know how to fix this. ive read up that its the 4 little torx screws in the column. how do i get to these? i have the steering wheel and airbag off now. does anyone have any good pics how to do this?
    thanks
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    The only other thing left to remove it the turn signal switch. Just remember to use loctite on the bolts when you put them back in.
    CT
    2001 camaro Z28
    how do i remove the turn signal switch? and the plate this in the middle of the steering column gets removed?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Quote Originally Posted by ls1curt View Post
    Ya have to remove the plate and IIRC, there are torx screws holding the turn signal switch in place. Most GM's are set up that way.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    A destruction manual is your best friend.
    Haynes, Chiltons, Etc.....
    tx
    pewter
    99 trans am ws6
    that switch is a pain in the ass. you have to unplug it for under the steering column and then pull it out through the top of the column
    CT
    2001 camaro Z28
    ok, cause i got down to the white plate, with all the springs and stuff in it, i just gotta figure out how to get that out now
    CT
    2001 camaro Z28
    i got down to the bare column. i can get to one bolt but it was already pretty tight. how do i take the metal part of the column off to get to the other 3 bolts?
  1. Loose steering
    By slims00ls1z28 in forum GTO
    Last Post: 07-15-2012, 02:23 PM
  2. Loose steering wheel.
    By CamaroFan71 in forum General Help
    Last Post: 09-27-2008, 05:39 AM
  3. So I noticed my steering is Loose?
    By Patsy57 in forum Road Racing / AutoX
    Last Post: 06-26-2008, 12:33 PM
  4. Loose Steering
    By H1tmanSS in forum General Help
    Last Post: 09-09-2007, 11:17 PM
  5. Steering loose
    By absolutetraction in forum Suspension and Handling
    Last Post: 10-26-2005, 07:26 PM
