Thread: shifting problem
05-26-2009, 11:11 AM #1Junior Member
- Sep 2008
- Kitimat Bc Canada
shifting problem
Well I got 1992 GMC sierra 4x4 700 r4 and I only can get first gear the problem started when I went to pull a hill and the trani would go from third to first but I could mechanically change it to second. When I got home I checked fluid level and it was fine, but my kickdown linkage at the tbi had popped off and the housing at the bottom had bein pulled up and busted and was now slightly cocked. I've fixed the housing with some crazy glue once it was all sitting thier probably and the problem still exists any suggestions?
05-26-2009, 02:53 PM #2Senior Member
- Feb 2006
- Orange County, NY
The kickdown cable has to be adjusted perfectly to shift correctly. Also if it is wrong you can burn up a tranny. Try posting in the transmission section. You can also do a search in google for tv cable adjustment.
05-26-2009, 07:28 PM #3
If the TV cable broke, change it, hopefully your trans is still okay.
05-26-2009, 09:01 PM #4Junior Member
- Sep 2008
- Kitimat Bc Canada
i bought a brand new cable and adjusted it i got first and if I beat the shit of it I get third in drive but just first in overdrive
05-26-2009, 11:50 PM #5
had something simulare happen in my dads 92 suburban 2wd on -40 day, turns out a bearing spun somewhere. I wasn't there to when the diagnosis happened, but he got a brand new tranny.
05-27-2009, 09:45 PM #6Junior Member
- Sep 2008
- Kitimat Bc Canada
roughh well mine if you hit about 60km/hr in first gear you get the next gear I doubt I spun a bearing but something did pack it in. I did however use a book for some help and I did all the checks I could with out pulling the pand and stuff off so it is something internal.
05-28-2009, 07:03 PM #7Junior Member
- Sep 2008
- Kitimat Bc Canada
Well i just pulled my tranny out today and you can't really turn the input shaft anymore and when you do the output dosn't turn like it's suppose to so I put my new tranny in thier about 2 hours ago and got most of things in thier just have to finish resembling it all tomorrow.
02' shifting problem
By johnfin in forum Firebird / WS6Replies: 14Last Post: 07-08-2012, 05:31 AM -
shifting problem
By edrvsqz1980 in forum Firebird / WS6Replies: 8Last Post: 02-24-2012, 11:13 AM -
shifting problem
By Camaroride32 in forum DrivetrainReplies: 0Last Post: 04-27-2008, 04:23 AM -
Shifting Problem please help!
By timpointzero in forum DrivetrainReplies: 3Last Post: 12-01-2005, 08:44 PM -
Shifting Problem M6
By ss~zoso~ss in forum Camaro / SSReplies: 20Last Post: 11-06-2005, 09:33 PM
