Thread: shifting problem
02-23-2012, 06:12 AM #1
shifting problem
I just noticed last night that it was really hard to shift into reverse and then this morning I noticed that it was really hard to shift to 1st and 2nd gear. Anyone know what it is?
02-23-2012, 07:11 AM #2
Clutch going out would be my guess...
02-23-2012, 07:19 AM #3
I hope not i just had it changed under a year.
02-23-2012, 08:24 AM #4
Check the fluid level in your master Cylinder.
Sent from Motorola ATRIX 4G on Tapatalk2000 T/A-DMH Cutout, SLP Cold Air kit, FTRA/SLP Upgrade, SLP Bilstein, LT1 Eibach ProKit, Kuhmo PA31 Tires ,SLP Fan Switch, UMI Double Adj PHB w/ Roto-Joints, UMI LCARB, Strano 35/22mm Sway Bars , Magnecor KV85 Wires, Hurst Shifter, Lou's Short Stick.
02-23-2012, 09:28 AM #5
How many miles on the tranny?
Check the fluid level first but sounds like the sychros are going out.
02-23-2012, 11:14 AM #6
just checked the fluid on the master clutch cylinder and it is good. Now i cant shift over to reverse without getting grinding. From what i believe the transmission hasn't changed so it should have 80,000 miles.
02-23-2012, 12:52 PM #7
this may help you
http://www.ls1.com/forums/f65/common...t-56-a-159573/
02-24-2012, 11:10 AM #8
Grinding = bad synchros in the tranny.
02-24-2012, 11:13 AM #9
^ +1 A throwout bearing can make a grinding noise too.
02' shifting problem
By johnfin in forum Firebird / WS6Replies: 14Last Post: 07-08-2012, 05:31 AM -
shifting problem???
By blk00ls1 in forum Almost Anything GoesReplies: 3Last Post: 02-01-2009, 03:00 AM -
shifting problem
By Camaroride32 in forum DrivetrainReplies: 0Last Post: 04-27-2008, 04:23 AM -
Shifting Problem please help!
By timpointzero in forum DrivetrainReplies: 3Last Post: 12-01-2005, 08:44 PM -
Shifting Problem M6
By ss~zoso~ss in forum Camaro / SSReplies: 20Last Post: 11-06-2005, 09:33 PM
