Results 1 to 10 of 10
    Junior Member Blown Z's Avatar
    Apr 2009
    maryland
    1998 Z28
    coolant lines!!!!!!!!!!
    i need the intake manifold coolant lines for a ls6 does any one know where i can find them?
    Apr 2009
    maryland
    1998 Z28
    thanks bud
    Millennium Falcon mpfranks's Avatar
    Akron, Oh
    2000 Trans Am WS.6
    or you can just cut and braze your old ones and save yourself the money. thats what i did. it was what the directions said for my Weiand intake. heres the link to their instructions with illustrations (pg. 4). its really easy.
    http://www.holley.com/data/Products/.../199R10267.pdf
    Quote Originally Posted by mpfranks View Post
    Thats what I did too.
    Akron, Oh
    2000 Trans Am WS.6
    no reason to spend $60 on something you dont need.
    Nov 2008
    Alberta
    dark blue
    2000 pontiac trans am ws6
    Hey. MpFranks, did you notice any gains from your weiand Ls1 intake manifold over the stock? does it come with intake gaskets and throttle body gaskets? was thinking of getting ls6 but the weiand is more budget friendlier
    thanks
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Besides the pre 01 lines have "better" cooling capabilities for the rear cylinder anyways.
    Akron, Oh
    2000 Trans Am WS.6
    Quote Originally Posted by Mr.Lee View Post
    thanks
    the weiand intake is an ls6 intake. its just not made by gm. so yes, i noticed the same gains as everyone else. and it does come with all the gaskets and hard ward. the only thing that was a bitch, was the connectors in the back for the wiring harness on the MAP sensor and vacuum lines. it took a little bit of fudging around because the placement on the back of the intake is different, so i had to lengthen the wires. if you look at the link i posed, in figure 4., it showes where the MAP sensor attaches to the intake. well the wires dont reach it. also, in the same picture you can see where there are 2 openings for the vacuum lines, well the stock one only has 1, but has 2 fitting on the one opening. well the second opening on the weiand is directly in the way of the MAP sensor, so i also had to plug the second opening, and fabricate a dual fitting for the one side. (using the barbs provided, and brazing them together) hope that makes sense. basically it was a HUGE pain in the ass. if i wouldnt have gotten mine for such a cheap price i would have gotten the ls6. i also just wanted to keep my egr/air, my qtp headers have it too. just depends on what you want. over all, since it all done and running great, im happy with it, but at the time ive never had an intake manifold give me so much trouble, so i hated it, lol. youll need a lot of patience, and a good mechanical background to attempt this. if you want to avoid ALL headaches then then just spend the extra cash and just go with the ls6. my $.02
    Nov 2008
    Alberta
    dark blue
    thanks buddy, ya i'll go wit the ls6 then and i think it's lighter too!
  1. LS6 Intake with no coolant lines
    By WS6Dream in forum External Engine
    Last Post: 05-03-2011, 12:25 PM
  2. Coolant bypass lines/plugs LS6 Swap
    By Vertiviper in forum External Engine
    Last Post: 04-25-2010, 02:42 PM
  3. coolant lines under my intake??
    By tbias in forum External Engine
    Last Post: 07-08-2009, 09:19 PM
  4. Head Crossover Coolant Lines.
    By speedkills in forum External Engine
    Last Post: 10-26-2007, 02:45 PM
  5. Transmission Coolant Lines
    By LETHALxLS1 in forum Parts Wanted / Trade
    Last Post: 05-29-2007, 08:01 AM
