Results 1 to 19 of 19
Thread: coolant lines under my intake??
01-30-2009, 03:14 PM #1Member
- Sep 2008
- kansas city mo
black- 2000 camaro ss
hey guys,
Ive trying to put my ride back together and Ive ran into another problem. My car is an 00 with the coolant tube going right under the center of of my intake so they recommend i upgrade to the pre ls6 coolant lines that come up the front only. After buying the new lines it looks to me like they just block off the rear holes and pushes water in the front ones. Is this right? it sure don't seem like a better way to cool to me. is this a better setup? thanx for any imput..
01-30-2009, 04:14 PM #2
did you just put an ls6 intake on your car?
01-30-2009, 04:30 PM #3
yup they are just little blockoffs on the back.
you could just trim the bottom of your ls6 intake to fit over the collant (steam lines) if you are doing an intake swap\upgrade
01-30-2009, 05:51 PM #4Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Yeah, it blocks off the back...the reason I got the LS6 Coolant lines is because the stock LS1 lines don't fit with the LS6 Valley Cover.
01-30-2009, 06:36 PM #5
you can cut your lines so that they only run side to side. then braze the cut ends. thats what i did, it was what my instructions told me to do for my ls6 intake. works perfect, no problems and its free
you can find details instructions in this manual
http://www.holley.com/data/Products/.../199R10267.pdfLast edited by mpfranks; 01-30-2009 at 06:45 PM.
01-31-2009, 02:48 PM #6Member
- Sep 2008
- kansas city mo
thanks for clearing it up for me. I have a typhoon intake i got a great deal on it . Thanx for the link mpfranks that lingenfelter guy knows a little something about gm power thats for sure (just orderd some heads and a cam from them).Does this pre ls6 style cool better? Ive already bought the stuff to switch it over but im curious.
01-31-2009, 04:16 PM #7
01-31-2009, 04:21 PM #8Member
- Sep 2008
- kansas city mo
i got ya . thanks again for all the imput.
01-31-2009, 04:24 PM #9
anything to save someone else from the headaches i went through with mine, lol
02-01-2009, 09:28 AM #10Member
- Sep 2008
- kansas city mo
I hear ya . Its a pain the ass working on these things but its all gonna be worth it when i hand it to this kid up the street in his mustang!
02-01-2009, 09:38 AM #11
02-01-2009, 08:12 PM #12
02-03-2009, 09:03 AM #13Member
- Sep 2008
- kansas city mo
he just got it amonth ago and my ss has been torn apart for 4 months now ! Shes gettn a h/c/i swap baby!!
07-07-2009, 02:45 PM #14Junior Member
- Nov 2008
- Alberta
dark blue- 2000 pontiac trans am ws6
hey mpfranks
just installed the weiand ls6 intake manifold 2 weeks ago...what a pain in the butt! u were right about lengthen that wire but i had no issues wit the 2 vacuum lines in the back...other than that it was fine....till 2 days ago the weiend ls6 intake manifold had a vacuum leak underneath it where u screw on that plate on the back...so had to take out the intake and apply sealant to the gasket and plate...how annoying...
07-07-2009, 03:25 PM #15
That plate came with a gasket. That's odd. I've had no issues with mine. Outside of that, what do you think about it?
07-07-2009, 03:46 PM #16Junior Member
- Nov 2008
- Alberta
ya that plate did come with a gasket but i guess there was still a vaccuum leak coming from it..i thought it was a worn bearing or sumthing on a pulley...but used a stheoscope and it confirmed the noise was either from tb or intake and so i decided to spray brake cleaner on tb, egr tube, and underneath the intake and soon found out a whole bunch of white smoke came out of my exhaust so i knew there was a vaccum leak occuring where the plate was. The noise was a really high pitched WEEEEEEEEEEEEE, sounded like a supercharger, a half ass one.
But ya just to give u a heads up that a vacuum leak could occur at the plate and i solved it by applying sealant on the gasket and outside of the plate to make sure no leak would ever occur.
other than that, since i got it for $370 brand new, can't complain and u do notice gain's in the upper band of rpm. Like u said before, it's good to have the egr since i too have egr set up on my long tube headers.
just wondering, do u have ur car lowered? was planning on lowering it, but dunno if if i can since i have pacesetter long tube and y...
07-08-2009, 08:01 AM #17
well luckily i havent heard any "weeeeeeeeeeeee" noise yet. but i guess ill know what it is if i do hear it. yeah my car is lowered, but i havent installed my QTP longtubes yet. my y-pipe does drag sometimes on pretty steep driveways and such. but either way, the look of a lowered fbody is totally worth it.
07-08-2009, 12:04 PM #18Junior Member
- Nov 2008
- Alberta
ya i would love the lowered look for sure, what kind of set up do u have on ur suspension shock/spring combo? i also heard that just getting eibach springs ontop of stock shocks will not work and something about getting a adj pan bar or something like that? any reasons y?
07-08-2009, 09:19 PM #19
LS6 Intake with no coolant lines
By WS6Dream in forum External EngineReplies: 13Last Post: 05-03-2011, 12:25 PM -
coolant lines!!!!!!!!!!
By Blown Z in forum External EngineReplies: 9Last Post: 05-27-2009, 12:51 PM -
Transmission Coolant Lines
By LETHALxLS1 in forum Parts Wanted / TradeReplies: 6Last Post: 05-29-2007, 08:01 AM -
HELP!! i need coolant lines and block off plates for ls6 intake ASAP!!
By Stu's '00 Z in forum Parts Wanted / TradeReplies: 3Last Post: 12-05-2005, 07:10 PM -
ls6 intake coolant plugs or extra front coolant pipe?
By mikes ss in forum External EngineReplies: 3Last Post: 12-03-2005, 04:13 PM
