Results 1 to 3 of 3
05-22-2009, 05:43 AM #1
need a clutch, what about flywheel?
I ordered some parts for the car. I should be pushing around 410hp at the wheels. On the bottle, I hope to be around 500ish. I am getting a stage 2 clutch from KYSpeed.com. My question is, should I keep my stock flywheel, get a billet steel, or an aluminum? Money is tight, so I dont want to get a flywheel if I dont HAVE to have one.
05-22-2009, 06:42 AM #2
I guess it would depend on what you want it for....If you do a lot of roll racing then probly the aluminum would better suit you. If you go from a dig then the stock one will have more inertia to get the car moving. If money is a factor I would probly keep the stocker and just check it to see if it needs to be re-surfaced.
05-23-2009, 01:16 PM #3
I orderd it. I just went with the billet steel. It's in between, like, its not as light as the aluminum, but its lighter than the stocker
Flywheel, clutch, other
By Tide in forum GTOReplies: 4Last Post: 03-03-2009, 07:44 PM -
Help: ls1 clutch and flywheel
By Sarge08 in forum Internal EngineReplies: 0Last Post: 10-31-2008, 08:27 AM -
LS2 clutch set with flywheel
By sammy burks in forum Parts For Sale / TradeReplies: 16Last Post: 04-17-2007, 07:32 PM -
z06 clutch for sale, pressure plate clutch disk and flywheel
By themack56 in forum Parts For Sale / TradeReplies: 2Last Post: 07-06-2006, 07:15 PM -
Z06 clutch/pp/flywheel?
By TARZAN in forum Manual TransmissionReplies: 6Last Post: 09-22-2005, 06:55 AM
