    Local Bum TARZAN's Avatar
    Memphis Area
    Cobra, Z28, GN, F250
    Z06 clutch/pp/flywheel?
    I'm considering upgrading my stock stuff, and my car is basically stock....What are the pros and cons of this?
    Thanks,
    -Will
    I Fixed Da Rear jimbo98z's Avatar
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    The Z06 stuff is pretty much stock replacement parts now. In my opinion, for the money there are better things to be had. I just recently (about 500 miles ago) put a spec stage 3 kit in my car (kept my heavy flywheel) and I've been nothing but impressed. Can't say anything about wear.
    Also, if your car is a 1998 or older, go ahead and upgrade to the newer slave cylinder while you're in there, it seems to help keep the pedal light with heavier duty clutches.
    Hope this helps.
    Memphis Area
    Thanks....I was told that the Z06 clutch and PP were a definite upgrade over the stock stuff.....How true is this?
    -Will
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    It will be an upgrade over 2000 and older stuff, how much of an upgrade I'm not really sure. There definately isn't anything wrong with the Z06 Clutch package.
    Go Vols! x10-wakerider's Avatar
    Memphis
    SLP Camaro SS
    I went with the z06 clutch package. I havent had any problems with it at all. No Chatter!
    Memphis Area
    Thanks guys
    -Will
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    i spent an extra 200 over the zo6 clutch and got the ram powergrip hd with a billet flywheel and love it! stiffer than stock, but stronger than the zo6! I replaced the spec 3 i had with it..it was garbage! didnt last long at all and it only saw the track one time and 3 passes! :
  1. For Sale: PA: LS2 clutch set and LS1 flywheel
    By Shea in forum Parts For Sale / Trade
    Last Post: 04-07-2009, 08:55 AM
  2. Flywheel, clutch, other
    By Tide in forum GTO
    Last Post: 03-03-2009, 07:44 PM
  3. Help: ls1 clutch and flywheel
    By Sarge08 in forum Internal Engine
    Last Post: 10-31-2008, 08:27 AM
  4. LS2 clutch set with flywheel
    By sammy burks in forum Parts For Sale / Trade
    Last Post: 04-17-2007, 07:32 PM
  5. z06 clutch for sale, pressure plate clutch disk and flywheel
    By themack56 in forum Parts For Sale / Trade
    Last Post: 07-06-2006, 07:15 PM
