Results 1 to 2 of 2
    Tulsa,OK
    Quick Silver
    2002 Z06
    Knock sensor explaination please?
    Okay I see stuff about the knock sensor all the time and know it has something to do with timing I think??
    1. What is it.
    2. Why are people always upgrading it to the lt4. My Body said his car ran alot better after it, I have a 96 t/a and it runs fine as far as I know, but if this has not been replaced is it something I should do?
    Thanks!
    Beaumont, Tx
    Blue GMC Canyon
    trans ams gone now
    if you have lt's, or a bigger cam then they can set off more vibration and noise causing the knock sensor or module to pull timing to make up for it. the lt4 km wont be as sensitive to these things and wont pull the timing thus letting you keep more of your hard earned power.
  1. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 06:26 AM
  2. will bad knock sensor knock down hp
    Last Post: 10-14-2010, 04:49 PM
  3. Question: knock sensor
    By alkaydenz-28 in forum General Help
    Last Post: 12-20-2008, 01:12 PM
  4. Knock Sensor ?
    By 99DROPTOPZ in forum General Help
    Last Post: 11-03-2007, 07:32 PM
  5. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 08:28 AM
