    Junior Member Ls1manSS's Avatar
    cold spring
    01 SS
    just bought 02 ss
    het guys i just picked up an 02 ss with 40k on motor, it has long tubes with slp exhausht, lid with k&n, th 400 trans with 3500 stall and 9 inch with 410s. now i have about 3,500 dollars left over. any ideas on what to buy to get the most hp with the money i have left. im planing on doing heads/cam/intake/and fuel system. i just want to see what you guys would do or what kind of heads/cam/etc, that you would do to your own. thanks for the help. pm me or write in this post if you have any ideas.
    Member Eric1987's Avatar
    Long Beach, California
    1999 Z28 Convert
    What kind of rims do you got? I hope its still not on stock 245's. If it is get some bigger rims with tires. Any suspension mods? SFC's?
    おれわCamaroがいじん! chaosinfinite's Avatar
    Washington D.C.
    1998 Chevrolet Camaro SS
    Subframe connectors are a must. To be honest I would do the suspension upgrades first if I were you. The car has power already, so you need the suspension to keep up with the power. Also you can do the C5 Vette brake conversion to boost your braking power without spending 1k on a big brake system. Only works though if your rims are larger then 17". Another minor bolt on I would recommend is a larger throttle body. Is your car an auto, or a manual? If it is a manual does it have the skip shift eliminator kit on it? Another good upgrade that is cheap and very good is a transmission cooler. Hope these suggestions help.
    cold spring
    01 SS
    the car does have subframe connectors, i have a trans cooler from my 66 nova drag car i just sold. lol and yeah it does have stock wheels and tires. and i was thinking about doing a fast 90/90 set up, but i have heard that wiends new manifold is actually putting close to and on some cars even better numbers than the fast. what do you think about that?
    nut butter Poppn's Avatar
    Connecticut
    1999 Camaro SS
    Quote Originally Posted by Eric1987 View Post
    im pretty sure all the 98+ SS's came with 17x9 wheels all around with 275/40/17's.
    so even if they are "stock", you have a decent size wheel on there. just put some good rubber on
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    If the wheels and tires are 275's... that is plenty for performance. Some stickey tires on those rims would be fine. Hell, even a MT ET on a 16" rims will dead hook
    As far as FIRST mods.... I would stray away from the FAST 90/92 intake and throttle bodies. They are a great intake.... but unless your highly modded.... do other things first. Cam/heads/suspension.
    Build in progress...
    Senior Member SS02's Avatar
    None
    Rims are not next!
    He needs some sup...
    They cannot be 245 can they?
    Correct me if wrong!
    1999 Z28 Convert
    Well my Z28 came with 245's so I assumed that his did too. Fuck I got jipped!
    LE #2823 CamaroDMD's Avatar
    Oregon
    Red with Silver Stripes
    2002 Camaro SS LE
    The Z28s came with 245s, the SS came with 275s stock.
  1. Just bought 08 Z06
    By clint195 in forum Corvette
    Last Post: 01-09-2010, 05:14 PM
  2. Bought a WS6
    By stangereater in forum Firebird / WS6
    Last Post: 09-15-2009, 07:54 PM
  3. Bought a new toy....
    By buswwa in forum Almost Anything Goes
    Last Post: 07-13-2008, 09:49 AM
  4. Bought another gun
    By MagicMan in forum Almost Anything Goes
    Last Post: 05-13-2008, 06:57 PM
  5. Just bought a 99' FRC C5
    By Quickshift_C5 in forum Corvette
    Last Post: 12-05-2006, 04:33 PM
