Results 1 to 15 of 15
    WA
    99 FRC Corvette
    Just bought a 99' FRC C5
    Hey guys, just traded in an 02' Mustang GT that I had been modding for a while and got a black 99' FRC C5. Great car so far, I love absolutely everything about it. All the things that I hated about the Mustang were cured with this Corvette. The handling is fantastic (Z51 suspension right?), the brakes are better than the Cobra brakes I put on the Mustang, the power is MUCH better, the driving position is fantastic, and the modding potential is WAY better than a 2V GT any day.
    Anyway, I love the car and am now trying to fix all the the "little" things that I've been noticing about it. Here's a few things that I've noticed. I've done some basic searches online, and I'm sure you guys have come across this stuff before...so I apologize for the repetition if that's the case. Anyway, I appreciate in advance and suggestion/comments you guys may have about these issues:
    1. Clunk from rear end when shifting (not always, but often)
    2. Chattering/ticking from engine (read that these have a LOT of audible engine noise)
    3. Air leaking when listening to exhaust, giving it quick revs (most likely exhaust leak from the stock midpipe to whatever catback was installed)
    4. Check Engine Light - Code: P0410 (PCM) Secondary Air Injection System
    I would love to see what you guys think about these things, especially the Check Engine Light. Got about 5mi from home straight from the dealer when this light came on. He had just put a full tank of gas in it for me, so I naturally assumed that he must have not tightened the gas cap all the way down. So I went ahead and did this and after several driving sessions the light had not cleared. I grabbed the code off the car and then cleared the codes so it turned off the check engine light. I called the dealer and he said that he had put premium in the tank and was certain of it, and that someone else had filled the tank and he wasn't sure if the gas cap was on all the way or not (OR you can't fill your own gas). I tightened it myself to double check, and tonight the Check Engine Light came back on. I like to think positive, so I assume it's either low-grade gasoline in the tank or the seal is bad on the gas cap. The car seems to run fine, although a bit rough. The performance is there and I don't see any other issues related to this.
    What do you guys think?
    Looking forward to you replies!
    2000 Corvette
    As far as the chattering, are the headers stock? Mine was noticeable after the addition of longtubes along with valvetrain work.
    The rear end noise, does it happen in certtain gears or all gears? Mine has this when I am in reverse ir first. Common, just need to snug up the main bolt back there (although I don't remember exactly what the term is, I think its the hub bolt??)
    Congrats on the car, you are going to love it. The FRC are lighter than the other Vettes so you have a good power to weight advantage, good luck on your other issues.
    Corvette Moderator BlownC5's Avatar
    Essexville
    Jet Stream Blue
    2009 Lingenfelter ZR1
    Congrats, I've got a 99 FRC myself so I can definately say you made a wise choice!
    2009 JSB Lingenfelter ZR1
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    hmm the chattering...try swamping ls2 or newer heads..i believe they moved to float point pins or something like that..it stops piston
    mods- suncoast creations hood with functional lt1 style airbox, ls6 intake, QTP longtube headers, QTP ORY, UMI SFC, Adj. LCA with relo brackets, UMI adj. panhard bar, Koni SA and strano springs,Torq Thrust M 17s 9.5 and 10.5 with nitto 555Rs, tuned by Frost
    Quote Originally Posted by Modulistic View Post
    sometimes you get owned, sometimes you own.
    Ell Ess Won
    Guest
    nice! im buying a FRC myself. should be nice
    Member smokeyburnouts's Avatar
    Pittsburgh
    2002 Pontiac Trans Am WS6
    FRCs are great cars. congrats
    san luis obispo
    i have one as well, with a blower lots lots lots of power
    Junior Member 99FRCtrochred's Avatar
    California
    torchred
    99 FRC Vette
    You could not have made a better choice. I might me prejudice because I have one.
    Junior Member yaknow's Avatar
    Lino Lakes
    2000 Corvette FRC
    Great choice
    ramona,ca
    2000 ss camaro
    Rear End Clunking
    I have a 99 Torch Red FRC what a awesome car. as far as the clunking in the rear,I had the same problem,I took the car to the dealer as I have the extended warranty,told this was normal,that weekend I changed the differential fluid to Mobil 1 syn. and also gm posi additive and no more clunking.
    Junior Member Cornfed's Avatar
    Colorado
    1999 FRC Vette
    Member Frosty's Avatar
    Near Philly
    White/Silver
    1989 GTA 98 GTP coupe
    The tensioners on these things are loud, that could be your engine noise.
    -98 GTP Coupe. Silvermist and stock.
    -89 GTA*** L98, P1-SC, 24# SVO's, MSD 6-A, March underdrive pulleys, Edelbrock headers/catback and some other goodies.
    ~Tony
    Every day is a gift-enjoy preston1980's Avatar
    Missouri
    Torch Red
    1999 Corvette Hardtop
    I love the look of the FRC Vettes, I think the hard top looks so much better than the Hatch glass Cars. Plus lighter and stiffer, good choice. I actually think a regular Hard top 99/00 vette looks better than the 01 - 04 ZO6.
    By the way, what does the C stand for, is it Fixed Roof Corvette or Fixed roof Coupe or Fixed Roof Compartment, compact? or what? I never did know, just know that it means hard top. Maybe it just means Fixed Roof Car.
    And yes the FRC's came standard with the Z51 suspension, so have fun cornering.
    Member cujo's Avatar
    Buffalo
    Silver, Black
    03 Viper, 05 Escalade
    FRC=Fixed Roof Coupe.
    Junior Member Rob Petyo's Avatar
    NJ
    1998 Corvette C5
    Congrats on the upgrade!
    Have you tried clearing (resetting) the codes?
  1. Just bought 08 Z06
    By clint195 in forum Corvette
    Last Post: 01-09-2010, 06:14 PM
  2. Bought a WS6
    By stangereater in forum Firebird / WS6
    Last Post: 09-15-2009, 08:54 PM
  3. Just bought SFC's and LCA's
    By silversho89 in forum Suspension and Handling
    Last Post: 03-20-2009, 06:57 AM
  4. Bought a new toy....
    By buswwa in forum Almost Anything Goes
    Last Post: 07-13-2008, 10:49 AM
  5. Bought another gun
    By MagicMan in forum Almost Anything Goes
    Last Post: 05-13-2008, 07:57 PM
