Results 1 to 3 of 3
Thread: Bleeding Brakes with a Line Lock
05-09-2009, 02:30 PM #1Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I installed a SJM Line Lock and I then bled the brakes. Now my brakes are REAL soggy. Did I do something wrong with the installation? Should the Line Lock be activated or deactivated when bleeding the brakes?
05-09-2009, 04:16 PM #2
Loosen the fitting on the ABS, while someone is pushing the brake pedal slowly, then tighten after the air blows out. Don't engage it... You might still have to bleed the front brakes, if you worked air through the lines also.
05-09-2009, 04:18 PM #3
I should be at 75-80 for T&T tomorrow, if you want to test it out !!!
Help: Bleeding brakes
By SStrokeME00 in forum General HelpReplies: 1Last Post: 06-14-2012, 05:56 AM -
Bleeding brakes
By c5z28 in forum Suspension and HandlingReplies: 4Last Post: 08-26-2010, 09:29 PM -
Question: Bleeding Brakes?
By BRICKYARDDTX in forum General HelpReplies: 18Last Post: 07-13-2009, 09:52 PM -
Brakes are spongy after Line Lock install...
By ls1camino in forum Suspension and HandlingReplies: 2Last Post: 07-04-2009, 01:06 PM -
Bleeding Brakes ?????
By EastTNZ28 in forum General HelpReplies: 2Last Post: 10-04-2007, 11:54 AM
