Results 1 to 2 of 2
Thread: Bleeding brakes
06-13-2012, 03:38 AM #1
Bleeding brakes
So I took the ABS module completely out if the car, unplugged and everything, and now I'm trying to bleed the brakes. Problem seems to be that the ABS module doesn't seem to be letting any fluid through. A friend of mine says that you have to reset the module. I've googled it and can't find anything. I'm completely lost, I've never dealt with this before. Can anyone help me out so I don't have to tow this thing to the stealership?
Sent from my HTC PH39100 using Tapatalk 2
06-14-2012, 05:56 AM #2
I believe that you will need the stealership for this one. You need a scanner/computer that allow the user to manually open the ABS valves to bleed them out completely. I'm sure someone else will chime in to confirmed this. Have you tried bleeding them for a while one side at a time?
Need some input bleeding brakes....
By 5abivt in forum General HelpReplies: 8Last Post: 10-11-2010, 03:05 AM -
Question on brakes (bleeding)
By TokerM in forum General HelpReplies: 14Last Post: 09-30-2010, 12:02 PM -
Bleeding brakes
By c5z28 in forum Suspension and HandlingReplies: 4Last Post: 08-26-2010, 09:29 PM -
Question: Bleeding Brakes?
By BRICKYARDDTX in forum General HelpReplies: 18Last Post: 07-13-2009, 09:52 PM -
Bleeding Brakes ?????
By EastTNZ28 in forum General HelpReplies: 2Last Post: 10-04-2007, 11:54 AM
