Results 1 to 11 of 11
Thread: Alignment issues
05-08-2009, 01:52 PM #1
Alignment issues
I just had my car aligned today and it drives straight now, but there's still about 1"-1.5" of play in my steering wheel. I can rock the steering shaft back and forth by hand, so my question is, how do I get rid of the slop?
05-08-2009, 03:06 PM #2
It only had this play in the wheel after it was aligned?? So it was fine before the alignment??
1998 Trans Am WS6 SGM
Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
05-08-2009, 03:12 PM #3
05-09-2009, 01:12 PM #4
you guys didn't look hard enough at his statement.
try tightening the two bolts that hold the steering shaft to the rack and up near where it goes into the firewall. second thing to do is turn the big adjusting nut on the rack to tighten it up. in this pic you'll see it on the right side shiny.
05-09-2009, 06:32 PM #5
05-09-2009, 06:35 PM #6
so, you replaced the rack? if so, then really check the bolt that holds the shaft to the rack. i thought i had mine tight enough at first. had hte slop and went back and tightened it more.
no, that was lack of oil. here's the whole video
http://www.centralfloridastreetcars..../caronfire.wmvCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-09-2009, 06:37 PM #7
05-09-2009, 06:41 PM #8
And damn, that was pretty crazy!!! I'm guessing the track officials were pretty pissed
I'm guessing the wife isn't very happy you let her oil get so low!?
05-09-2009, 06:43 PM #9
was full of oil up until hte rod went out the oil pan. dropped pressure.
yeah, she wouldn't talk about it for three days
05-09-2009, 06:47 PM #10
05-09-2009, 06:50 PM #11
me and that was back in jan 2006. went back to a stock motor. LS6 block. still have the vinci lid, k/n filter, 3.73 gears, bassani headers and tru-duals on it.
Help: rear end alignment issues
By godless-phoenix in forum Suspension and HandlingReplies: 43Last Post: 12-02-2011, 03:57 PM -
Alignment issues with new suspension pieces
By HOBS in forum Suspension and HandlingReplies: 0Last Post: 09-13-2011, 06:21 PM -
Wheel Alignment Guide - DIY Alignment
By Ed Blown Vert in forum Almost Anything GoesReplies: 5Last Post: 08-06-2009, 03:30 PM -
Oil Pan Alignment
By 68Impala in forum External EngineReplies: 3Last Post: 11-01-2007, 03:52 PM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM
