Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
Thread: 4l60E
    Member mrwdjv's Avatar
    Apr 2009
    South Carolina
    Purple
    4l60E
    This is the transmission in my car....is that good?
    Homebrew Master irishpenguin13's Avatar
    Aug 2006
    leesburg, florida
    1997 Trans Am
    anything is good if you take care of it.
    Aug 2006
    leesburg, florida
    1997 Trans Am
    u might wanna put this in the drivetrain section under automatic transmissions.
    Greene, Iowa
    99 Chevrolet Camaro Z-28
    well jee....every other automatic transmission in a fbod just happens to be a 4l60e so im gonna take a wild guess and say its a good transmission? you know there are other forums on this website other than anything goes...last i knew there was a specific drivetrain forum for these kind of questions...i may be mistaken though
    Aug 2006
    leesburg, florida
    1997 Trans Am
    ok, im trying not to laugh. but this isnt helping...^
    Greene, Iowa
    haha
    Apr 2009
    South Carolina
    Purple
    Sorry guys, I thought ya'll knew everything and this would be my best bet for an accurate answer!
    Aug 2006
    leesburg, florida
    1997 Trans Am
    im thinking she just posts just to post.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    hey..lets not be a dick...and some people will argue that the 4l60e is not a "good" transmission for the f-bod ..since it needs a good amount of internal work to make it handle power/torque
    Aug 2006
    leesburg, florida
    1997 Trans Am
    Quote Originally Posted by mrwdjv View Post
    to what "is that good"??? i dont know what to say to that.
    Apr 2009
    South Carolina
    Purple
    People who are looking at buying my car have asked what transmission is in it. I had to call GM to find out. I didn't know if that would hurt or help the value.
    Aug 2001
    San Diego, CA
    383 w/Meth & ProCharger
    2001 Camaro Z28
    Of course the 4L60e is very debatable on how tough it really is. I paid $3k to make it as stout as possible and no issues so far. I don't race it all the time nor have the line pressure's set high.
    The TH400 and 4L80e are stronger transmissions but they have a few headaches of their own. But then again any transmission will have some temperament, nothings perfect.
    Shepherd, Michigan
    98' trans am
    the 4l60e stands for 4 speed- longitudinal- 6,000 gross weight (of the vehicle) - E for electronically controlled.
    the 4l60e is a good transmission with the proper maintenance.. it is increadabiliy picky on fuild amounts..just a smig to high or low will really wreak havoc on your transmission. the 4l60e has been replaced by the 6l60e which is in the corvettes etc. both are good transmissions..but when modding..a heavy look needs to be had at the transmission..a build up of the transmission is always a good idea. The 4l60e is prone to overheating and causing damage due to poor clearances for proper fluid flow. for a everyday DD with little to no mods a 4l60e is perfect and pretty trouble free..just make sure to not manually shift the transmission.
    Greene, Iowa
    2 transmissions in these cars that had the v8...t-56 (6 speed) and 4l60e (automatic)
    Aug 2001
    San Diego, CA
    2001 Camaro Z28
    Overall it's a really good transmission for a stock fbody. Just when you start pumping 600+ rear wheel horsepower into it....then it's getting questionable. But hey, that's alot of hp.
    Aug 2006
    leesburg, florida
    1997 Trans Am
    right on, my car is as stock as can be and never had problems yet.
    Shepherd, Michigan
    98' trans am
    there were only 2 transmissions available with the 98-02 f-bodies..the 4l60e (also called A4) and the t-56(m6). 1 automatic and the other manual
    in general with any performance car..manuals will command a higher resale value.
    there are a set of rpo codes on your driver side door..they are 3 digit codes...you can look them up on line and it will tell you every option that was selected for the car.
    Shepherd, Michigan
    98' trans am
    you beat me
    Apr 2009
    South Carolina
    Purple
    The 4L60-E is an automatic shift, four-speed overdrive, longitudinally positioned transmission. It is now considered to be the best rendition of the finest overdrive automatic transmission ever produced.
    http://www.novak-adapt.com/knowledge/4l60e.htm
    Shepherd, Michigan
    98' trans am
    i know the big problem is the trans fluid clearances between parts..it can lead to heat related failures.that and the bands and input shaft... that is why when the time comes.. i will be sending my trans to FLT to do the stage 2..maybe 3 for mine.
  1. which 4l60e's are the same as 02 lsx......
    By jsmith564` in forum Automatic Transmission
    Last Post: 07-06-2011, 06:30 PM
  2. Need a 4l60e 98-02
    By ROMERO98Z28 in forum Parts Wanted / Trade
    Last Post: 05-10-2011, 05:07 PM
  3. wtb lt1 4l60e..
    By pr0zac in forum Parts Wanted / Trade
    Last Post: 11-16-2006, 01:49 PM
  4. '95 4L60E vs '01 4L60E biggest difference?
    By kgrantkey in forum Automatic Transmission
    Last Post: 04-28-2006, 12:09 AM
  5. LT1 Motor, LT1 4L60E, & LS1 4L60E
    By buck6680 in forum Parts For Sale / Trade
    Last Post: 09-05-2005, 07:41 PM
