Results 1 to 20 of 20
    Junior Member timowen1's Avatar
    Feb 2006
    Tipp City, Ohio
    Mystic Teal Metallic
    2001 Trans Am
    AC Delco oil filter question
    I did a search on our forum and did not find exactly what I was looking for. A PF 46 is what my LS1 uses and I was wondering if the PF 61 would work. It looks identical but is about 2" longer. Has anyone used or using the PF61 on a regular basis?
    Thanks.
    Tim
    Marylandistan
    2001 Trans Am (sold)
    I always use the PF61. Longer filter increases oil capacity slightly and more filter media.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by INMY01TA View Post
    Yup. Truck filters. Works the same, increases oil capacity, just gotta be careful if your lowered...
    Senior Member
    Newport, RI
    '00 Formy A4
    Oh good info...I was wondering about this myself.
    Now I know what filter to get next time.
    Good info! The first time I changed the oil, I looked at the filter and said, "You have got to be kidding me!"
    Senior Member
    Newport, RI
    '00 Formy A4
    I know, cute little thing, isn't it? Looks like something off a Briggs & Stratton.
    Beaver Dam KY
    79 T/A -91 Firebird
    I use the truck filter by K&N. Its got the giant nut on the bottom so i can change oil without jacking the car up...
    Member km346's Avatar
    Nov 2008
    masssaaechuuuseettes
    1998 hardtop SS
    Ive always used the pf61, no problems here.
    Midwest
    2002 Trans Am
    Quote Originally Posted by km346 View Post
    How far past the oil pan does the PF61 extend?
    thanks.
    old timer blue02Z's Avatar
    2002 Z28
    ^^^^^ i think maybe an inch, my headers hang lower than my filter. i also run a pf61
    Nov 2008
    1998 hardtop SS
    Quote Originally Posted by johnb View Post
    thanks.
    Its about flush with the K-member, no lower then the factory y pipe does...
    Midwest
    2002 Trans Am
    Thanks, guys. I'm going to look into this. The stock filter looks like it goes on my lawnmmower.
    I already run extended filters on my Buick DD and the wife's Pontiac van.
    USA
    Velocity Yellow
    2008 Corvette Z06
    I've been PF46'in for years with no problems.
    Junior Member SS1Eagle's Avatar
    Apr 2009
    Connecticut
    Black SS SLP#8834
    2002 35th Anniversary LS1
    What is the Mobil 1 equivalent of the PF61 filter?
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Mobil 1 M1206
    Member iam_dale's Avatar
    Bann, Germany
    02 WS6
    Good info, guys! I'll keep this in mind when I do my next oil change....too bad I just did one!!
    dale
    Member blackcar's Avatar
    Arkansas
    '02 Z28 parting-out
    thanks.
    On the K&N version the filter in 1 inch longer.
    http://www.knfilters.com/search/prod...x?Prod=HP-2006
    http://www.knfilters.com/search/prod...x?Prod=HP-1007
    I wish is showed capacites.
    Arizona
    Quote Originally Posted by timowen1 View Post
    Thanks.
    Tim
    I've been running the PF61 forever. I've compared it to the other longer filters and found that the A/C 61 is actually a tad longer than all the others and holds a bit more.
    You can find them at Walmart,,,I buy mine there all the time for $3.69
    I actually stock up on them and buy 4-5 when they have them,,,,,because they seem to sell fast.
    I did a write up on this comparing the size of all the available filters a couple years ago. Doing a search might turn it up.
    Arizona
    Stick that next to the AC PF61 and you'll find that the K&N is still smaller.
    Beaver Dam KY
    79 T/A -91 Firebird
    and Ill also break the oil filter off then when I drive it down my driveway
  1. Replies: 18
    Last Post: 10-13-2021, 09:38 AM
  2. AC Delco Filter # ?
    By racerbrowns SS in forum Camaro / SS
    Last Post: 03-26-2011, 01:03 PM
  3. Replies: 32
    Last Post: 03-11-2011, 05:36 PM
  4. AC Delco Air Filter better fit
    By va2001ss in forum General Help
    Last Post: 04-30-2009, 12:32 PM
