Results 1 to 10 of 10
Thread: how is your setup?
03-31-2009, 04:03 PM #1Member
- Jun 2008
- ohio
black- 1998 Camaro SS
how is your setup?
i have hsw single nozzle dry. i want to mount the bottle between the 2 rear seats in my 98ss. does anyone have a similar setup? how did you run your lines......just drill a hole in the floor and got underneath?
04-05-2009, 03:14 PM #2Junior Member
- Apr 2008
- Encinal, Tx
just cut a hole in a rubber plug in the floorboard
04-06-2009, 07:57 AM #3
I mounted my bottle in between the 2 rear seats and I love where it is! I cat out a 3 1/4" piece of particle board and put black carpet on it. I mounted it at an angle and then mounted the bottle brackets to the board and mounted the bottle. You need to get a blow off valve and a clear hose to run to the back where the spare tire is and place the tube through a grommet to vent in case of an emergency you dont want N2o venting inside the car. Plus, most tracks wont let you run if you dont have one set up. I ran the braided nitrous line down under the passenger rear seat and then it runs under the carpet along the passenger side and through the grommet in the fire wall. Check out the link ............
http://s726.photobucket.com/albums/w...TransAm044.jpg
04-06-2009, 08:49 AM #4
^^^Thats how ive done every one of ours.
02 Camaro
PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
*Old Time* 10.90@ 125mph
04-08-2009, 11:01 AM #5Member
- Urbandale, IA
Red- 2002 Trans Am WS6 (M6)
Mine's on the rear hump as well. I made a custom braided blow down line that runs from the bottle to the grommet under the rear passenger seat. It's hooked into a metal plate under the car so it can't pull back through the rubber grommet. The actual nitrous line runs under the center console, through the passenger side firewall grommet, and to the solenoids.
04-17-2009, 11:49 PM #6
04-17-2009, 11:52 PM #7
04-18-2009, 03:34 PM #8
Yeah, just poke it through the plug in the floorboard.
-Will
04-19-2009, 06:07 AM #9Member
- Jun 2008
- ohio
did you make that bracket to hold the bottle or buy it somewhere?
04-19-2009, 03:08 PM #10
Will a MSD setup really help?
By Street Fighter in forum General HelpReplies: 3Last Post: 12-31-2010, 09:37 AM -
Anyone with this setup?
By davidz28 in forum External EngineReplies: 2Last Post: 03-30-2010, 05:33 PM -
WTT: My 4L60E setup for your T56 setup!
By 4birdman in forum Parts For Sale / TradeReplies: 1Last Post: 03-16-2007, 12:26 PM -
Can i run this setup?
By 94 Formula in forum Forced InductionReplies: 4Last Post: 01-16-2007, 01:25 PM -
will this setup fit?
By switchblade in forum Wheels and TiresReplies: 1Last Post: 07-26-2006, 07:36 AM
