Results 1 to 2 of 2
    chicago
    will this setup fit?
    looking to buy this setup: 18x9.5 (+56 mm offset) and 18x10.5 (+58mm offset)
    255/35/18 up front and 305/45r-18 in back. the rear tires would be nitto drag radials (nt-555r). will those offsets work, and is the rear tire size too tall and/or the front tire too short? what size tires would you run on these size rims? this is for a 2000 camaro, by the way.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    fronts will work. i test fitted the 18 x 9.5" C5 wheel with 285/35-18 on the wife's car. real close to the spindle, but fit. on the rear, i had to clearance the inner fenderwell on the front side with the same wheel. 305/45-18 is going to be really tall. with the sizes you want to use, it will cause ABS issues. you would need a 305/30-18 tire to keep the front/rear heights the same. you might be able to clearance the inner fenderwell enough to clear it.
  1. Will a MSD setup really help?
    By Street Fighter in forum General Help
    Last Post: 12-31-2010, 09:37 AM
  2. Anyone with this setup?
    By davidz28 in forum External Engine
    Last Post: 03-30-2010, 05:33 PM
  3. WTT: My 4L60E setup for your T56 setup!
    By 4birdman in forum Parts For Sale / Trade
    Last Post: 03-16-2007, 12:26 PM
  4. Can i run this setup?
    By 94 Formula in forum Forced Induction
    Last Post: 01-16-2007, 01:25 PM
  5. 02 LS1 Ram Air Setup
    By damiano1 in forum Parts For Sale / Trade
    Last Post: 08-24-2006, 06:21 PM
