Thread: Umi lcas
    maine
    2002 z-28
    Umi lcas
    i have a pair of lower control arms, that i put on my camaro last year, but they squeeked every time i went over a bump, so i took them off.......im getting ready to uncover the car, and get it ready for the warm weather driving, and id like to put them back on , any way to stop the squeeking??
    the lcas have spherical rod ends , and grease fittins on the other end.....which didnt do anything for limmiting noise.
    thanks for any help you guys can give me!
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    Mine have not made any noticeable noise when I replaced them (I have the exact same ones). Some things to check though that might be leading to the noise.
    Make sure that you have them on the correct way (spherical end towards the rear end).
    Did you apply any of the lubricant supplied (I smeared it all over every bit that has movement) ?
    This is more for clunking, but make sure that the adjustment nut is really tight otherwise the spherical end can get loose and bind up and make it sound like you are having rocks thrown up against your floorboard.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    I just bought some LCAs and did not get spherical rod ends because several people stated that they make a lot of noise. I also read that the suspension has to be "loaded" when you install the LCRs or they could make noise.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    You cant have the suspension loaded and install LCAs. Impossible.
    UMI's instructions say to torque them while the suspension is loaded though...
    Smear the ends with marine grease. Its what the reccommend.
    Fairfield, Ohio
    00 WS6
    Sorry, that's what I meant to say.....
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by qwk93ta View Post
    I got ya covered lol
    maine
    2002 z-28
    thanks guys,,,,ill give it a try........!!
    Junior Member deepblue's Avatar
    Tennessee
    blue
    2001 WS6 Trans Am
    I thought my LCA's where squeaking also, but after installing the new UMI LCA's and it still squeaked i looked at my sway bar bushing. I used a little Teflon grease on them and it stopped.
    2001 Pontiac Trans Am WS6, M6, Moser 12 bolt 4.10 gear,
    SLP Lid, SLP Smooth Bellow, Ported & Polished MAF, Fast TB, Fast Intake,Comp Cams XER281HR-12,
    Jet Hot LT Headers, Jet Hot Y pipe, SLP Loud Mouth.
  1. UMI LCAs
    By Orcus79 in forum Parts Review
    Last Post: 06-14-2009, 06:51 PM
  2. LCAs
    By TempleU_WS6 in forum Suspension and Handling
    Last Post: 01-02-2009, 08:21 AM
  3. SFCs and LCAs
    By BMJ99Z28 in forum Suspension and Handling
    Last Post: 01-01-2009, 07:01 PM
  4. Which LCAs ?
    By Bottesini in forum Suspension and Handling
    Last Post: 10-26-2007, 01:01 PM
  5. how good are these PHR & LCAs?
    By StylesMcKnob in forum Suspension and Handling
    Last Post: 10-10-2007, 01:16 PM
