Results 1 to 11 of 11
Thread: LCAs
11-30-2008, 10:39 AM #1Awaiting Activation
- Sep 2007
- Philly+Glenmoore, Pa
LCAs
Ok, im gonna order UMI LCAs but should i get adjustable ones or just non-adjustable?
Also, whats the benefit of the relocation brackets for them?
Another note, what should I look for as far as new motor mounts? And should I do new trans mounts while im at it?Last edited by TempleU_WS6; 11-30-2008 at 10:43 AM.
11-30-2008, 01:26 PM #2
Adjustables for sure. If you do a rear upgrade, it won't fit like the old one...
As far as motor mounts, I'm still running my stock ones... I will go with the polly ones later !
11-30-2008, 02:10 PM #3
11-30-2008, 02:26 PM #4
My 98 stock mounts are still good, and I've been drag racing it for at least 5 years now !!!
11-30-2008, 02:33 PM #5
11-30-2008, 02:54 PM #6
Mine are adjustable... never adusted them yet!
U might help me there?
I cannot help more then that Temp, sorry dude!
I had to reply 2 Ur thread man... I do have adjustable ones!
11-30-2008, 04:07 PM #7Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
get the adj ones, as for the relocation brackets, it provides more leverage on the rear end to help eliminate wheel hop and increase traction by holding the rear end from twisting. if you plan on making more power or already do and you wanna actually put up some decent times, both of these are essential
12-18-2008, 08:07 PM #8
12-19-2008, 02:08 AM #9
I would get the adjustable ones just to have the rod end on one end.
12-19-2008, 03:00 PM #10Party Time, Excellent...
- Jan 2008
- Bay Area, California
Arctic White- 2000 Z-28
Adjustable, it is better spend money once and buy something you might not need rather than having to order new parts because you didn't get them in the first place
01-02-2009, 07:21 AM #11Member
- May 2008
- delete me too
Well, to answer your question, if you are set on getting the motor mounts done (i did), it is definitely worth it to do the transmission too. If you make the engine mounts stronger, the vibration will only be more excessive when it gets to the transmission. That's at least what I've heard, and makes perfect sense to me.
UMI LCAs
By Orcus79 in forum Parts ReviewReplies: 12Last Post: 06-14-2009, 05:51 PM -
Umi lcas
By 2002ls1 in forum Suspension and HandlingReplies: 7Last Post: 03-27-2009, 01:11 PM -
SFCs and LCAs
By BMJ99Z28 in forum Suspension and HandlingReplies: 8Last Post: 01-01-2009, 06:01 PM -
Which LCAs ?
By Bottesini in forum Suspension and HandlingReplies: 11Last Post: 10-26-2007, 12:01 PM -
how good are these PHR & LCAs?
By StylesMcKnob in forum Suspension and HandlingReplies: 11Last Post: 10-10-2007, 12:16 PM
