Thread: rear end noise :(
03-20-2009, 04:09 PM #1
rear end noise :(
so my 2002 ss is getting a fairly loud noise most likley from the rearend, its best described as a high pitch whine and sometimes when i stop from a high speed clicking. The car has 55,000 miles and the po said he never changed the rearend i dont think he would lie we go to the same church. What does everybody think it is, ring and pinion?
03-20-2009, 04:17 PM #2
Check out the U-joint in the rear, may also want to drain the rear end fluid and take a look at it, make sure its not chunky or full of garbage, then refill and ensure you add some lmtd slip additive.
03-20-2009, 04:49 PM #3
ok ill check, i didnt think the u joint would make a whining noise
03-21-2009, 11:49 AM #4
Make sure your spare tire is in there correctly if you haven't already. I put mine back on with the spacer facing the wrong way once. OMFG it sounded like a Sherman tank.
03-23-2009, 10:52 AM #5
- Oct 2005
- Pocola, OK
Black- 2000 TA
If you hear a click - click - click when slowing down it could be your u-joints. They can dry up and rust.
03-26-2009, 07:40 PM #6
Normally noise on decel is ring and pinion but like they said above, check your u-joints, it's easy and free. Just remember, he goes to church because he is a sinner, and sinners lie!!! (that was a joke)
rear end noise
By rickus in forum DrivetrainReplies: 14Last Post: 07-05-2010, 09:36 AM -
Rear End Noise
By nasdag in forum DrivetrainReplies: 4Last Post: 06-21-2010, 10:22 AM -
Rear end noise
By BDESHIFTER98 in forum DrivetrainReplies: 3Last Post: 10-08-2009, 04:00 AM -
Question: rear end noise
By Brad(WS/Z0.6) in forum DrivetrainReplies: 12Last Post: 02-13-2009, 12:45 PM -
Rear end noise
By 980birds in forum DrivetrainReplies: 1Last Post: 03-22-2007, 03:01 PM
