    Feb 2006
    ks
    2000 Trans am
    fog lights turn signals
    Hi, Im new to fourums Don't really know how they work. Just wondering how to replace the front turn signal, and the fog light bulbs.
    Member cobrakiller99's Avatar
    May 2008
    Michigan
    1999 Trans am Ws6
    i dont know about the signals, but i replaced my fog lights from inside the hood.
    Houston, Texas
    2000 C5 Torch Red
    two ways for the turn signals. Two little bolts under front bumper on each side. Drop those and a flap opens where you can get to the blinkers.
    Other way is to stick your hand in the lower open section and twist pull. just make sure you don't scratch the paint.
    I did method 2 until replacing upgrading my housings with LED's. Now there's no more leaks or burnouts. Hurray!!!
    Member raysz28's Avatar
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    If you are just replacing the bulbs it isnt very hard, if your replacing the turn signal housings, the way I did it was to remove the front bumper. My stock turn signal housings kept getting water in them and breaking the bulbs, so I replaced them with aftermarket clear housings. But if your just replacing the bulbs this is how I did it...
    Turn signals – it was done mostly by feel. Reach inside the engine bay from the top till you feel the top of the turn signal housing. There is a tab that needs to be pressed in, then you will be able to rotate the bulb to replace it. The small bulb at the end of the housing is a simple twist in and out.
    Fog lights – this is easiest to get at from under the car. You will find there are two access doors in front of each tire. Remove the screws and open the panel. From there you will have the room to get to the back of the fog lights and twist in and out the new bulbs.
    Hope that helps.
    98 Ticket Red Z28
    Mods:
    Front/rear sway bars, poly bushings all around, Bilstein Shocks, Centerforce Dual Friction Clutch, Pacesetter LT's, 2.5" Custom True Duals over the axle with Magnaflow mufflers, Shortened Pro 5.0 shifter, TurnOne PS pump.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Quote Originally Posted by raysz28 View Post
    Hope that helps.
    Birds and Maro's are different on Fogs and Turns.
    Just FYI.
    Member onetroubledguy's Avatar
    Dallas, TX
    1999 Trans Am WS6
    That's what I did if you're just replacing a bulb. Really easy.
  1. Help: Turn Signals are all solid lights
    By kjfine1971 in forum General Help
    Last Post: 11-19-2010, 10:34 AM
  2. Help: parking lights and turn signals
    By thatguys_ws6 in forum General Help
    Last Post: 03-15-2010, 05:26 PM
  3. Tinted Turn Signals, Rear Lights, Bumper Lights
    By BADASS2000SS in forum Camaro / SS
    Last Post: 02-19-2009, 01:10 AM
  4. T/A - lights under turn signals?
    By mariner3302 in forum Appearance Section
    Last Post: 09-25-2007, 03:36 PM
  5. Turn signals and brake lights don't quite work..HELP!!
    By Kaution vBi in forum General Help
    Last Post: 08-05-2007, 09:45 AM
