Results 1 to 20 of 35
Thread: A4 shift points
    Member supaxero's Avatar
    Sep 2008
    desert
    metallic pewter
    2000 Trans Am WS6
    A4 shift points
    was thinking about changing the shift points, any pros and cons
    Pittsburgh
    2008 Hummer H3
    Wink
    Quote Originally Posted by supaxero View Post
    I had my trany reprogramed for crisper shifts. Also to eliminate slow roll turning up hill slip that the a4 is sometimes known for. Pros on mine where harder engagement when getting on it. Cons, seems the ASR is less effective and it spins anyway. Hope than helps. Good luck.
    Senior Member SS02's Avatar
    None
    I had my rev limiter rasied and my shift points at my Dyno Tune. It made
    a difference.
    None
    I forgot... I turn my ASR off just after I start it, it never sees snow....
    well and I like to drive!
    if you're still on the stock valvetrain I wouldn't recommend it but if you have aftermarket stuff in there go ahead and bump them up some.
    Sep 2008
    desert
    metallic pewter
    2000 Trans Am WS6
    I recently added a few mods. Small cam upgrade, typhoon intake, headers . The transmission was just upgraded to handle some serious horses. How high did you change the shift points?
    Sep 2008
    desert
    metallic pewter
    2000 Trans Am WS6
    Quote Originally Posted by SS02 View Post
    Sorry, im not sure I understand.
    I live in a canyon and that drives me nuts!
    How come?
    Pittsburgh
    2008 Hummer H3
    Wink
    Not sure if you're askin me but mine was reprogramed just for cleaner shifting points. Trany just reacts better less sluggish than the factory set up. Also holds gears better like a mild shift kit. Nothing crazy though.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    How come?
    Was making me crazy too. I only had 40,000 on the ticker when I noticed it. Peed me off to no end cause the car was still relatively new. But after explaining this condition to the tech who worked on it, he called me and explained it was a common thing and a simple reprog would make it shift a little more aggressively. Never had it come back either.
    I should look into that. It seems to happen more going up hill and around corners. If I put it into D before I hit the canyon I'm usually OK. And, sometimes happens on flat land from a stop going around corners
    I've got 73K.
    What did it cost you?
    Pittsburgh
    2008 Hummer H3
    Wink
    I've got 73K.
    At the time it was covered under my warranty. Cant be too bad though they just plug it in and change from their computer or scan tool. Hope that helps.
    Should correct yours too.
    PS. I'm over 75,000 now still has'nt come back.
    Pittsburgh
    2008 Hummer H3
    Hey KahanaReef. The main reason I even worried about it was I did'nt know if when it was catching if it was begining to hurt my trany. I did'nt want it to become permanent.
    I baby the heck out of her and would lift as soon as I felt that spot in between gears. That feeling is what a dead automatic feels like when it's in gear but wont fully engage. If that makes any sense to ya. Just drove me up the wall when I drove it. Haveing it checked and programed gave some peace of mind back too.
    Pittsburgh
    2008 Hummer H3
    Wink
    I've got 73K.
    I keep thinkin' of stuff. But you might look into haveing your trany flushed and fluid changed. They pump it out to clean out the converter too then put fresh fluid it the whole thing. Cause cant get the bad fluid out of the converter when dropping only the pan.
    Yeah, pretty much know how that works. I'm sure it's about time to do it too.
    I drove around in a 'slip and slide' power glide for a few years and it reminds me of that
    I'll see about taking it in and having it done.
    Thanks.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    how much would it cost to get shift points moved?
    I have no idea. That's what I would like to know
    Pittsburgh
    2008 Hummer H3
    Wink
    I'll call the shop in the morning and get back to you right away. I dont see it costing that much.
    I'm in PA. so morning will be here sooner for me too.
    Pittsburgh
    2008 Hummer H3
    Wink
    Thanks.
    Oh the old "slip slide power glide" two speed. My Dad had an old 65 f-85 Olds with that set up. Had the old Jetfire 330 small block. HAHA well small to Olds. Olds motors had that humungus intake and wide spead between the banks.LOL
    by the time it was time to rebuild that tranny... it was alllll over the place! Quite the adventure just getting to work and back
    Oh, and don't worry about finding out how much it would cost. Pretty sure it will be way higher out here I don't want to take it to the steelership. So, I need to find someone out here to take it to. But, thanks for the thought
  1. Shift points?
    By Mystic Z-28 in forum Internal Engine
    Last Post: 03-05-2011, 03:56 AM
  2. new shift points
    By ssmike in forum Automatic Transmission
    Last Post: 07-25-2008, 11:04 AM
  3. Shift Points on A4
    By FantaZGuy28 in forum Drivetrain
    Last Post: 11-05-2006, 12:54 PM
  4. 323's to 373's shift points
    By Andy Lappin in forum Computer & Tuning
    Last Post: 06-19-2006, 12:36 PM
  5. What Shift Points Should I Use
    By MATTTRANS2000 in forum Drag Racing
    Last Post: 03-23-2006, 12:35 PM
