Results 1 to 14 of 14
Thread: No Power Steering
03-13-2009, 10:18 AM #1
No Power Steering
hey guys, last night i did a doughnut, and now i have no power steering? any suggestions on what could have happen. there is plenty of fluid in the reservoir, and i can turn the wheels, just no power steering. i was thinking it was the pump, but just wanted check what u guys first.
03-13-2009, 10:43 AM #2Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Remove the belt and pull on the pulley, if it pulls out the shaft is broken and you need a new pump.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
03-13-2009, 10:50 AM #3
ok ill try that
03-13-2009, 11:35 AM #4Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Or your belt is gone
03-13-2009, 02:39 PM #5
found out that the shaft broke off in the pump. bout to put the new pump on, but cant figure out how to get the pulley on with the shaft still in on it.
03-13-2009, 03:56 PM #6Senior Member
- Apr 2008
- Madison, WI
There is a pump pulley puller to get the pulley off the shaft and an installer to put it on the new one.
puller:
Installer:
03-13-2009, 05:37 PM #7
well i need a new pulley now, broke the old one. any suggestions? i know about Turn One.
but is there any other place i can find one at?
03-14-2009, 03:45 AM #8Member
- Oct 2005
- San Antonio
Silver & Black- 99 Camaro SS
Come with the details, tell us what you tried so others don't try it.
A couple of big screw drivers? A pry bar?
03-14-2009, 06:48 AM #9
03-14-2009, 07:13 AM #10Impounded
- Oct 2007
- Beaver Dam KY
The shaft broke off completely from the power steering pump and was rusted in the pulley WHICH IS PLASTIC with a metal insert so basically any force used to get the broken off shaft is gonna snap it.
TurnOne you NEVER have to take off the pulley unless your replacing the pump again. You can remove it without taking it off the car. Which makes it a fuckton easier.
03-17-2009, 11:45 AM #11
dont use a pry bar. it will snap it also. use the part mentioned above by cutlass. i didnt have one of those around, so i used a hammer, and a 10mm socket, put the shaft in a vice and gave it a few taps, and SNAP!!!! the friggen pulley broke....got another one on the way to the stealership. goin pick it up now.
04-04-2012, 08:23 PM #12
Im glad im not the only, i did a few donuts the past saturday and i belive im have the EXACT issue. This is the first time i did donuts in my t/a..
My steering gets really hard when im turning at slow speeds..i gas it and my steering gets soft/normal again and i noticed some what of a burned smell and aswell i noticed under the hood i had some what of a mist of p/s fluid on parts of my engine.
My p/s fluid is good and my pump seems fine atleat i think, no bubbles. Also a loud purring noise when the steering gets hard.
04-04-2012, 10:08 PM #13
lol listen to nightrider, we all pounded him on doing donuts and now its your turn. our cars DO NOT like donuts.
04-05-2012, 05:51 AM #14
Help: Power steering
By 1998ss in forum Stereo and ElectronicsReplies: 1Last Post: 09-17-2013, 03:02 AM -
I need power steering help
By transam_00 in forum External EngineReplies: 14Last Post: 01-11-2011, 07:51 AM -
Question: Power Steering, Manual Rack, Power Steering Pumps-etc
By TerribleTed in forum General HelpReplies: 2Last Post: 11-18-2010, 04:37 PM -
power steering is no more
By transamgirl89 in forum Camaro / SSReplies: 4Last Post: 08-20-2010, 06:27 PM -
power steering?
By Spikito in forum Camaro / SSReplies: 2Last Post: 06-19-2009, 10:51 PM
