Results 1 to 3 of 3
Thread: REar end noise
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    REar end noise
    I just replaced my carrier and and pinion bearing got the depth correct and set the backlash to .007 with new shims everything seems good until you start the car... If Im on the gas accelerating I notice a slight clunk like theres too much play in between the gears. As Im coasting to a stop between 45-20 mph the noise is very audible its just a constant clunk. Tried a few different things so far. When the car was jacked up i had the cover off and held a screw driver over to push the carrier into the pinion and the noise stops.However Im afraid to shim it tighter because the backlash is already good. The shims went in just like they should with a slight tap of a hammer. ive set up rear ends before and nevr had this prob if anyone knows please advise. btw gears are the originals in the car and they never had noise
    Dan-
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Did you use marking compound on the gears? What does the pattern look like?
    old timer blue02Z's Avatar
    2002 Z28
    if your preload on the pinion was set right25-30 inch pounds then you shoulda never changed the shims. when you change bearings only there is not really a need to change that. shit i dont even measure backlash or check my pattern if i install new bearings. did you get the cross pin back in right? BTW what kinda car is it
  1. rear end noise
    By rickus in forum Drivetrain
    Last Post: 07-05-2010, 09:36 AM
  2. Rear End Noise
    By nasdag in forum Drivetrain
    Last Post: 06-21-2010, 10:22 AM
  3. Rear end noise
    By BDESHIFTER98 in forum Drivetrain
    Last Post: 10-08-2009, 04:00 AM
  4. Question: rear end noise
    By Brad(WS/Z0.6) in forum Drivetrain
    Last Post: 02-13-2009, 12:45 PM
  5. Rear end noise
    By 980birds in forum Drivetrain
    Last Post: 03-22-2007, 03:01 PM
