Results 1 to 20 of 241
03-05-2009, 07:42 PM #1TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
Time for a new motor!!!!! INPUT requested
Ok so i just installed a FAST 92/92 about three weeks ago. I thought i had a vac leak (no biggie). I havent driven the car in about 4 or 5 days and it has been raining like crazy. So i go to start it and KA BAM!!!!! CLANK, CLANK, CLANK, CLANK............. Hydro lock is a $%*&. So now its time for a stroker. Anyone have any input on what to go with? Thanks in advance.
Ya know whats kind of funny is that i am almost happy. does that sound crazy?
02 SS
LQ9 408 Stroker ,M6 1LE, LT's, ORY, GMMG, STG2 LS6 heads,248/254 .612/.622, Tubular LCA's, Panhard, torque arm, tranny cross-member, upper and lower a-arms, k-member, 3 point SFC's, Baer 6 pistons up-front, stock rear
, Adj. coil-overs,
12.6@120MPH
81 Celica
18.1 @ 85MPH
03-05-2009, 11:21 PM #2
03-05-2009, 11:44 PM #3TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
I figure if im gunna do it, i might as well go big. i was lookin at a LQ9, around 500+wrhp, some what steetable. If i can i would like to keep my current heads (Patriot stage 2) as far as budget, i dont really have to much money now but i dont mind buying parts over time. looking to spend $4-5k. Thanks for the input.
03-06-2009, 07:20 AM #4
wtf happened??? Sorry to hear about that dude.
03-06-2009, 08:17 AM #5TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
I guess that vac leak was on the pass side right where i've been having some water pooling. It has been raining like crazy here and it must have got into the cylinder through the leak. So as soon as i started it, it felt like the whole car jumped off the ground. My GF came out of the house because she heard it and though i hit the house. It was so loud, so i turned it off. At first i thought it was the tranny or something cuz that where i felt it. so i restarted it for about 5 sec and it is def the engine. But now its just time to look on the brite side, now i can build that stroker ive been wanting
. Id like to think that everythings happens for a reason, mine is just to go faster....... Thanks for the support, its gunna be hard not being able to drive it but owell. maybe i can bum rides off other people
03-06-2009, 09:51 AM #6
03-06-2009, 09:59 AM #7
03-06-2009, 10:11 AM #8
03-06-2009, 10:14 AM #9TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
why not this......
http://www.hotrod.com/techarticles/7...ock/index.html
03-06-2009, 10:16 AM #10
03-06-2009, 10:17 AM #11
03-06-2009, 10:27 AM #12
03-06-2009, 10:34 AM #13
03-06-2009, 10:44 AM #14TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
I was looking at this. whacta think..............
http://www.texas-speed.com/SHOP/item...id=46&catid=28
03-06-2009, 10:46 AM #15
03-06-2009, 10:47 AM #16Senior Member
- Mar 2007
- Henryetta/Tulsa Oklahoma
Oh man, if I ever win a bunch of money....
http://www.texas-speed.com/SHOP/item...d=830&catid=82
03-06-2009, 10:54 AM #17
I know you want to re-use those heads but you might want to tear that one down and make sure nothing came back up and pounded the cylinder head since you refired it after the initial bang.
Something else to keep in mind,,,with those heads and their tight 59cc chambers you may want to spec a short block with a dished piston to keep compression in check,,,since you are talking stroker here which figures into the compression equation,,,those 59cc chambers on a stroker with a flat top will make a ton of squeeze that may be finicky on pump gas.
With that said I'm all for the cast iron block stroker kits. With room to spare for another rebuild down the road you can't go wrong.
03-06-2009, 10:57 AM #18
03-06-2009, 10:57 AM #19
03-06-2009, 10:58 AM #20
Help: I need some input on a motor
By 2fst4U! in forum General HelpReplies: 6Last Post: 02-28-2010, 11:11 PM -
Time for shopping, need some input
By SMWS6TA in forum General HelpReplies: 12Last Post: 02-04-2010, 11:22 AM -
time for a new motor?
By 01ssSLP in forum General HelpReplies: 12Last Post: 11-01-2008, 08:15 AM -
new motor time
By boosted z in forum Camaro / SSReplies: 0Last Post: 10-05-2008, 01:22 PM -
Time to start NEW MOTOR
By EastTNZ28 in forum Computer & TuningReplies: 2Last Post: 10-01-2007, 05:53 PM
