Results 1 to 13 of 13
Thread: time for a new motor?
10-24-2008, 09:05 AM #1
So i have a 2001 SS M6 and the #5 cyclinder spark plug keeps getting oil on it which mean its misfires. I have no idea what to about it other then put a new motor in but i dont have the money to do that right now. I know the
LS1's get piston slap ,which i have but not bad, so im guessing it got worse seeing as oil is getting on the spark plug. So my question is what should i do to fix other then a new motor.
10-24-2008, 09:29 AM #2Royal pain in the....
- Aug 2007
- savannah, ga
2001 Z-28 A4 NBM- 2002 35th anni SS M6#1696
valve stem seals
oil is leaking past seals and onto spark plug.
used to be more common, i would replace a couple of valve stem seals before i would go motor.
also a good excuse to do some head work
10-24-2008, 09:35 AM #3King 0f n00bz
- Jan 2006
- Shepherd, Michigan
yessir..no need for a new engine..its worth noting that piston slap has nothing to do with your issue. P/s is all about expansion to eliminate the play that the ls1 pistons get until they warm up..i cant remember what needs to expand but the later pistons solved this with the change to floating pin designs
10-24-2008, 01:17 PM #4
So getting new heads would solve this problem?
10-24-2008, 01:47 PM #5
10-24-2008, 01:53 PM #6
how much of a pain is that job to do or should i just let someone work on it
10-24-2008, 03:57 PM #7Exalted Cyclops
- Feb 2007
- San Diego, CA
Valve stem seals can be replaced without removing the head if you have the proper tools. The ones towards the back are a PITA though.
From my point of view (old, fat, lazy and with enough spare change to be able to afford to pay someone else to do it) I'd have a pro do the work.
10-25-2008, 12:09 PM #8King 0f n00bz
- Jan 2006
yea it involves rocker arm removal etc..so you need to prevent valves from dropping etc ..just go get it taken care of by a pro
10-26-2008, 03:06 PM #9
well then i guess monday i will being calling the shop to do some work. Hopeing it wont be to much. Thanks for the help guys
10-26-2008, 03:40 PM #10
Is there anything else i should get replaced while i have them do that or upgrade anything. i was looking at putting a trex cam in over the winter and in the kit it has the seals. would that work?
10-27-2008, 10:57 AM #11
Yeah man if you're doing a cam this winter you definitly want to put the new springs in when you replace the seals, so yeah put the seals and new springs for the cam in while you have it apart off...that'll be so cool to basically just throw the cam in.
10-27-2008, 12:05 PM #12Senior Member
- Feb 2006
- Orange County, NY
If you could do it I would do it all at once, no need to take things apart a second time. If they change the springs might as well do all the seals. I would have a leakdown test done to #5 just to be sure. Most likely just the valve seals though.
11-01-2008, 08:15 AM #13
I call the shop and they said they'll run a test and also said it might be a bad piston and not the seals. They gave me a price for at 500 so i hope no one out there has a problem like that.
Window motor replacement - what's your best time?
By jad628 in forum Almost Anything GoesReplies: 23Last Post: 06-08-2012, 09:16 AM -
200k... new motor time
By richard head in forum Internal EngineReplies: 4Last Post: 06-03-2011, 11:01 AM -
new motor time
By boosted z in forum Camaro / SSReplies: 0Last Post: 10-05-2008, 01:22 PM -
Time to start NEW MOTOR
By EastTNZ28 in forum Computer & TuningReplies: 2Last Post: 10-01-2007, 05:53 PM -
First time running new LS6 (ZO6) motor in the 1/8 mile, need help
By mglangley21 in forum General HelpReplies: 3Last Post: 07-14-2007, 07:37 AM
