    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    zexel-torson or auburn
    do any experts know definitively which cars came with which. i say the Z-T was standard on the z and ss with the auburn was the optional ss performance rear (ls1 years). what about lt1 years
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Regardless of option package, all V8 cars had the same differentials for any given year.
    The 93-98 cars had the Auburn Cone-clutch type differentials.
    The 99-02 cars had the Torsen Differentials.
    Hope that clears it up for you.
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    partialy. first , thanks second i remember when i was looking at my 01 i looked at the option list of ss parts and i thought i remembered a "auburn performance rear axle " option that was like 900 dollars?
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by twozs View Post
    Doesn't sound right...all the V8 equipped cars came with a limited slip diff standard, and there shouldn't have been an Auburn in an '01.
    Was it an automatic?? Perhaps you are thinking of the option that was for the 3.23 performance axle that comes with the SS package??
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Quote Originally Posted by Wesman View Post
    He's talking about an optional Auburn differential from SLP available on SS's and Firehawks only.
    SS's and Firehawks were available with several SLP extra cost options.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by 9T8W66 View Post
    Gotcha. That must be what he's thinking of then.
    1998 Trans Am WS6 SGM
    Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    aya, matie. thats what i thought, so standard z28, 1le, 4bc, and the standard ss and t/a, fourmla and ws6 had the Z/T but the firehawk and the ss were possibily optioned with the auburn. NOW, what was the diffrence?
    NJ
    SGM
    1998 Trans Am WS6
    The Zexel Torsen is a "torque-biasing" differential. Meaning its constantly distributing torque between each wheel. It has helical gears in constant mesh that can bias torque depending on the traction available. However, if one wheel has no traction at all (such as on ice or off the ground) the differential cannot distribute torque to the other wheel. Helical gear differentials do not wear out like conventional differentials do, because there it no clutch material.
    The Auburn diff is a cone clutch style differential. Its a limited slip, meaning if one wheel spins significantly faster than the other, the differential will distribute some of the torque to the opposite wheel. Even if one wheel has no available traction (such as on ice) it can still get the car moving by sending power to the other wheel. Since the Auburn is a clutch style limited slip, it can wear out over time, rendering it ineffective at distrituting torque.
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    thanks
  1. Zexel torsen 3.73s
    By Supersport0126 in forum Drivetrain
    Last Post: 01-25-2012, 02:30 PM
  2. WTB zexel 3 series differential
    By david_viny in forum Parts Wanted / Trade
    Last Post: 06-25-2009, 07:27 PM
  3. Zexel-Torsen Differential
    By RE98TA08 in forum Parts For Sale / Trade
    Last Post: 10-15-2007, 03:44 PM
  4. WTB: 99+ LS1 rear with Zexel-Torsen Diff 3.42
    By jagevileye21 in forum Parts Wanted / Trade
    Last Post: 03-16-2007, 06:20 PM
  5. Zexel HD or Eaton Posi
    By 99M6Z28 in forum Drivetrain
    Last Post: 07-27-2006, 04:29 PM
