Results 1 to 20 of 36
    Junior Member Johny Bee O's Avatar
    Switzerland
    Navy Blue
    2001 Camaro Z28
    Who drive with Mobil 1 0-40W oil
    Hi all
    I have problem with my engine. here is the link to my problem.
    I bought the camaro last summer 2008 with 138tkm fresh from oil service Fullsynthetic 5w40 oil. After 141tkm i have change the oil and the filter and fill it up with the Mobil 1 0w40. Now with 148tkm comes the problem...
    this spring i will replace the headgasket, collector gasket and and ..
    So now who drive with the 0w40 oil from Mobil 1? (Penzoil isnt available! in switzerland) any problems?
    I must found the reason for this problem, a headgasket doesnt sweating without a cause...
    So thanks for reading
    Member fergyflyer's Avatar
    Sep 2008
    Eustis, Fl
    2002 Z28
    I was using the 0-40 for a while till I noticed seepage around the main seal on my last 02 Z28. I switched back to 5-30 and the seepage went away.
    Junior Member slp1122's Avatar
    Nov 2008
    oc/las vegas
    pewter
    2000 camaro ss
    that oil is too thin for these engines
    MANWHORE TEAM suede's Avatar
    Your Mom's Bedroom
    Negro
    2000 Trans Am WS.6
    Quote Originally Posted by slp1122 View Post
    You base this on what?
    You can run it just fine, you just may notice more oil being burned/seepage as it is a thinner oil, but your climate determins alot, your pry not going to want to use it in warmer climate, but here in SD were a -35 degree start is not unheard of, it will be slightly more beneficial....
    Member CompSyn's Avatar
    Pacific NW USA
    Post M1 0w-40
    Quote Originally Posted by fergyflyer View Post
    That's interesting... M1 0W-40 is a thicker viscosity than 5W-30.
    CompSyn
    Marylandistan
    2001 Trans Am (sold)
    Chowchilla CA
    2001 Z28
    Who drive with Mobil 1 0W-40? People with bad grammar.
    Nov 2008
    oc/las vegas
    pewter
    2000 camaro ss
    you answered your own question. i have crazy leaks when i go too thin.
    Your Mom's Bedroom
    Negro
    2000 Trans Am WS.6
    It's still going to be better for certain climates, just gotta maintain it more....
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by lonewolf37 View Post
    This guy is from Switzerland dippy.
    Aren't you being a little bit critical???
    Switzerland
    Navy Blue
    2001 Camaro Z28
    Thanks for your support! i think your german must be better than my english...
    i try to write as good as i can... I think everybody should know what i mean, and we're not at school! thanks for understanding
    Chowchilla CA
    2001 Z28
    My apologies, I am a teacher, sometimes I just can't stop myself.
    Retired Outlaw Sum Bitch
    Any motor that "springs a leak" needs a internal cleaning...this eliminates many issues such as varnish/sludge up under gaskets etc. causing leaks....dirty rings causing oil consumption....
    I do not like solvent based cleaners as they are very hard on gaskets/seals. The thing I found works extremely well is this....AUTO RX
    Follow the instructions to the letter.
    Then see how your leaks etc. are.
    It is esters based (la natural)...and is really great at cleaning yes...but also swells seals and gaskets and allows them to reform...I have seen it stop leaks myself....and make the engine run so much better. A clean engine is a healthy engine guys....
    Switzerland
    Navy Blue
    2001 Camaro Z28
    Previously i check my engine again. Since the last engine cleaning its still dry, there is none new oil over or around the gasket. Strange things... hmm where flow the oil, when i fill to much oil in the engine ? Is there anywhere a overflow vavle or something else?
    Nov 2008
    oc/las vegas
    pewter
    2000 camaro ss
    i was poking around the site, seems they advise against synthetic oil, have you tried this stuff with synthetic?
    No they dont advise against it...just during the rine phase as synthetics have more robust add packs that would work against the Auto RX Esters.....so just during the rinse phase....
    Quote Originally Posted by Johny Bee O View Post
    I am talking about cleaning the inside of the engine. Do not overfill a motor with oil....too much oil causes much higher pressure and it will blow out seals/gaskets....
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Your english is still better than most of the people in this country.
    Your Mom's Bedroom
    Negro
    2000 Trans Am WS.6
    Quote Originally Posted by bigrondownhiller View Post
    sad but true...
    Marylandistan
    You do realize that 40 weight motor oil is thicker than 30 weight motor oil?
  1. mobil 1 help!?!?!?!?
    By unibuga in forum Firebird / WS6
    Last Post: 09-15-2010, 05:59 PM
  2. Mobil One Decal
    By lblak000 in forum Appearance Section
    Last Post: 02-14-2008, 05:34 AM
  3. Older than Mobil
    By Sarge in forum Almost Anything Goes
    Last Post: 09-20-2007, 08:20 AM
  4. if you use mobil 1 oils help me out
    By bmwmteam in forum General Help
    Last Post: 09-04-2007, 05:54 PM
  5. Well I'm making the switch........to Mobil 1
    By Hurley711 in forum Internal Engine
    Last Post: 01-31-2006, 11:51 PM
