Page 1 of 3 123 LastLast
Results 1 to 20 of 53
    7 (100%)
    battery hold down bracket...
    I made one of these for a member here and bought a 6' length of stock so I made a few extra's in case other people wanted them. I know it's common for the hold down to break.
    These are hand made and aren't perfect but they'll get the job done and I paint them flat black so they don't stick out. I test fit them on my battery which is roughly 7.5" wide x 7" tall so if you want to make sure this will fit just measure your battery and if it's close to that this will work. I couldn't decide whether this is worth $15 shipped or $10 shipped so lets try $12.50 shipped.
    - STOCK ish - Sarge91's Avatar
    Fairhope, Alabama
    2 (100%)
    2002 Camaro SS SLP
    I bought one, its great, it fit fine, and it holds it down nice and tight. Good price too.
    Hope they sell!
    2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
    7 (100%)
    bump
    sting like a Z redrallyeZ's Avatar
    Sugartit, SC
    bight rallye red
    do you have any on car pics?
    7 (100%)
    I'll snap a picture tonight.
    7 (100%)
    here's one unpainted:
    here's one painted:
    keep in mind that these are hand made so they're not machine perfect. I also suggest measuring your battery to see if it's the same as mine because I test fit them using my battery.
    Junior Member EchoMirage's Avatar
    New Jersey
    2002 Trans Am WS6
    is it a stock sized battery?
    7 (100%)
    Quote Originally Posted by EchoMirage View Post
    as far as I know it is. I never measured my stock battery. This one sits pretty much flush with that top radiator support and is just a shade under 7.5" wide.
    7 (100%)
    bump
    Fairhope, Alabama
    2 (100%)
    2002 Camaro SS SLP
    I thought i would take some pics to try and help the sell. BTW guys.. if your looking for a battery hold down bracket, expect to pay $30+ somewhere online. These may be homemade, but they are really good!
    Thanks again Orion
    7 (100%)
    thanks and glad you like it. The 2 other ones I have here I did something a little different to them after thinking about it and you should pull yours out and do. I put a couple coats of clear on them. Not sure why I didn't do that from the beginning. It'll just make the paint a little more durable and scratch resistant. The downside is they shine a little more but I don't think it's enough to make them stick out.
    Beaver Dam KY
    2 (75%)
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Orion you still got any of these left? If so just pm me
    7 (100%)
    yeah, I have 2.5 made out there now. Have a 3rd to paint but it's 16 degrees out so they're not getting painted until it's a little warmer. If you want one just PM me your info and I'll get one in the mail to you. Send me the money after you get it and put it on to make sure it fits fine for you and you like it. I'm not doing this to make money ( obviously by the price). It's just a common thing to fail on our car and is easy to make. I put every one of them on my car first to make sure it fits so if your battery is the same dimensions it'll fit yours.
    edit: I am making a couple dollars but my time is worth something. I have ~$5 in parts plus almost another $5 to ship after I buy the padded envelope so I'm making about $2. I can make $2 digging change out of my couch and it takes less time than these to make.
    7 (100%)
    shipped....should be there in 2-3 days.
    Beaver Dam KY
    2 (75%)
    79 T/A -91 Firebird
    7 (100%)
    bump
    have 1 painted and 1 or 2 to paint. These will probably be the last ones I make for a while unless someone requests one.
    8 (100%)
    Orion:
    Do you just place this in a padded envelope and send via USPS?
    If so can you check for additional shipping cost to my home zip code T1H 4X9?
    If it is too much will work it out for my US addy, it is just that I was there (in Montana) last weekend and am not exactly sure when I will go to the 'cabin' again/next.
    PM if you would like, if not just post here....
    G.M. SERVICE MANAGER LS16SPD's Avatar
    virginia
    navy blue metallic
    2000 z28 camaro
    orion, i like them alot looks great i built one for myself very similar to yours about 2 years ago.the only thing i did different was added some foam tape underneath the bracket so it wouldnt rub through the plastic
    4.10 RICHMOND GEARS,LAKEWOOD LCA'S,EATON POSI,EDELBROCK TORQUE ARM,
    LAKEWOOD PANHARD BAR,SLP LID,,B&M RIPPER SHIFTER,EDELBROCK STRUT TOWER BRACE,SLP FAN CONTROL,SLP LINE LOCK,17 INCH ZR1S WITH 315 35S AND 275 40S,SLP Y-PIPE,TSP 224/224 112LSA CAM,COMP SPRINGS,TUNED BY FROST @ LSXTUNE.COM
    7 (100%)
    Orion:
    yeah, I've just been shipping them through the usps. I'll stop in and ask them tomorrow and get back to you. PM me your name and address and if it's somewhat reasonable I'll just go ahead and ship it.
    7 (100%)
    Quote Originally Posted by LS16SPD View Post
    I had thought about doing that but there really shouldn't be enough vibration up there to cause any issues and it fits down on the battery pretty snug so the battery really shouldn't be moving. Someone could do that pretty easily though if they opted too. I ran mine all last year for the most part and when I took it off this year to start making these there wasn't even a mark on the battery from it.
  1. Battery Hold Down - Hold Down Hold Up
    Last Post: 06-06-2013, 06:20 PM
  2. Battery Hold Down Mount Replacement
    By SMWS6TA in forum General Help
    Last Post: 02-08-2011, 06:58 PM
  3. Battery Hold Down Brackets.....
    By 0rion in forum Parts For Sale / Trade
    Last Post: 04-26-2010, 03:56 PM
  4. WTB: Battery hold down and resivior for LS1
    By Black02LS1 in forum Western Members
    Last Post: 03-31-2009, 03:03 PM
  5. Help: battery hold down clamp is rusted on
    By Jeff3F in forum General Help
    Last Post: 04-07-2008, 10:39 PM
