Thread: new header ?
02-14-2009, 01:45 PM #1
new header ?
I put a set of texas speed long tubes on my ta and I got it out for a run up the road yesterday and when i got back to the house i was looking it over and say that somthing had moved and they are rubing the steering shaft.
has any one had this happen and have a way to fix it. i tryed to move the shaft a bit but its still to close for me.
02-14-2009, 03:47 PM #2
i know on my 04 goat, i have pacesetter longtubes. on hard acceleration the motor torques over just enough to hit the steering shaft and when its in the right position it grabs the bolt in the shaft.....scary at first, but i just got used to it.
if you have access to a torch, you might beable to get the runner hot and gently felx it alittle out of the way......i have a torch, but im just lazy
02-15-2009, 08:08 AM #3
Did your Y pipe shift? all header bolts inplace?
02-18-2009, 08:26 AM #4I need some money
- Feb 2007
- chandler az
hugger orange- 1999 camaro ss
mine is similar, my header hits just below the steering arm i believe its the crossmember, there is like a half an inch gap regularly and at wot or half throttle turning mine will rub it a couple times. i came to the conclusion that i need new motor mounts although i havent checked them yet. so good luck
thats my header!!!
02-18-2009, 12:14 PM #5
thanks guys im going to work on it this weekend some so i hope i can get it fixed. there was like 1/2 inch befor i got time to drive it so im hoping it easy to fix. i shold not need mounts i only have 13000 on the car so they should stilll be good.
Post LT header install header issues
By ob02z28 in forum External EngineReplies: 20Last Post: 02-18-2010, 04:10 PM -
Header ????? ####
By 1/4milerunnerZ28 in forum External EngineReplies: 22Last Post: 06-19-2008, 09:17 AM -
!!!Header ?!!!
By Bender10 in forum External EngineReplies: 7Last Post: 12-29-2007, 09:18 PM -
Little header help please?
By 2500HD4X4 in forum External EngineReplies: 6Last Post: 08-15-2007, 08:34 PM -
header help
By 1fastgto in forum GTOReplies: 4Last Post: 07-26-2007, 11:46 AM
