Results 1 to 13 of 13
    1998 Camaro SS
    42# injectors, fuel pump?
    im buying 42# injectors for the 98 ss with my new setup with nitrous. will i need to get a new fuel pump too?
    Glen Carbon, IL
    No need for a new fuel pump, but it won't flow max potential for injectors if you're making the power.
    1998 Camaro SS
    ill be making about 400rwhp and around 480 with the nitrous
    so i dont need pump then?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Well I don't see any point in NOT installing a Walbro 255 pump when they are under $100 right now. . . . . . . . . . Cheap insurance!!
    I do in EVERY car I put a kit on.
    1998 Camaro SS
    how difficult is it to install that fuel pump? and i have a 98 which has a metal tank right? does that make any difference in installing?
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    Pretty easy, as long as you dont mind cutting a hole in your car back in the hatch area. But if you do the "trap door method" make sure you use the instructions for a 98, because the 99-up are in a different location. One more thing, if you do decide to go this route, DO NOT cut very deep just cut deep enough to go through the metal, the fuel lines run right under where you will be cutting.
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Member squee's Avatar
    Baton Rouge
    2000 SS M6
    Quote Originally Posted by NoscamaroSS View Post
    Don't cut a hole in your car. Thats the lazy ass way to do something and its not all that bad dropping the tank. I do believe the 98s are a little harder though.
    Durant, Okla
    2002 Camaro
    ^^^Whys that? After you do it the first time, its only a 30 minute job to replace the fuel pump if it ever goes out.
    Baton Rouge
    2000 SS M6
    Because, thats the lazy ass way to do it. I said that already. Not to mention I simply wouldn't cut a hole in my car. If you where that worried about having to do it again, then just pull the pump, put a AN fitting in the bottom and use a external pump. Fuck cutting a hole in my car just to save a little time. Besides, if you buy a GOOD pump, it shouldn't go out...
    Aug 2000
    Indy
    whtvr savs tme
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    I cut a whole, it wasnt that bad. No one can ever tell.
    Durant, Okla
    2002 Camaro
    I guess 75% of 4th gen owners who have had to change a fuel pump are "lazy asses." Fuel pumps go out, if they didnt there wouldnt be no market for them. 30 min pump changes are hell of alot better than an all day project that involves you bench pressing a gas tank (because they always seem to go out when you have a full tank of gas), and no bigger of a hole that you cut when you silicone down your replacement cover nobody will know the wiser.
    Warminster, PA
    Quote Originally Posted by jmatt07 View Post
    Absolutely do a pump. I would also suggest running the hot wire kit like the one offered by racetronix as well.
    Nick
  1. Injectors...oil pump..need help
    By 95Fyrebyrd in forum V6
    Last Post: 08-01-2009, 04:39 PM
  2. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  3. Fuel pump for 40lb injectors
    By DSM Pimp in forum General Help
    Last Post: 06-14-2007, 11:10 AM
  4. fuel pump, injectors and air to water intercooler for sale
    By spankarooney in forum Parts For Sale / Trade
    Last Post: 11-02-2006, 05:18 PM
  5. smaller fuel injectors means more fuel?
    By Ger-Fire in forum LT1
    Last Post: 10-12-2006, 03:06 PM
