    pontiac_god
    Guest
    99 TA Rear Clunk
    Occasionally I can feel a clunk that is coming from the rear end when I accelerate from a dead stop. Also on the highway this morning at 2500 RPM (automatic) I could accelerate and decelerate back and forth and something is clearly loose back there. I could feel the car pulling - almost as though the axle is loose.
    Any ideas?
    Moo cow f**k milk Demon_Speeding's Avatar
    New Mexico...from Kansas City
    2001 Camaro Z28
    Tighten your lower control arm bolts. After installing my subframe connectors I had the same symptoms on my car. Tightening the LCAs fixed it.
    pontiac_god
    Guest
    Control arms are tight; I'm not sure why they would loosen......
    Junior Member alamantia's Avatar
    NJ
    1995 Z28 & 2002 Z28
    U-joint?
    99PontTA
    Guest
    Quote Originally Posted by pontiac_god
    Any ideas?
    how long have you owned this car..has it always done it? Try driving any other firebirds? these cars are clunky noisy in the rear...my wifes 99ta clunks like hell when you put it in reverse...and below 40 mph letting on-off the gas it clunks.
    pontiac_god
    Guest
    Quote Originally Posted by Demon_Speeding
    It was indeed the control arms. I tightened them to 80 ft/lbs...and the clunk in gone. However....I have some "slop" in the differential. With both rear wheels off of the ground, I could move each wheel with a fair amount of movement before the driveshaft moved. Any ideas about that one?
    99PontTA
    Guest
    yer god...and you don't know???? dayum..........sucks to be you...maybe keliente can help you figure this mess out.
    NJ
    1995 Z28 & 2002 Z28
    You'd better be able to move the wheels a fair ammount before the drive shaft moves or your gears would be toast, your fine.
    pontiac_god
    Guest
    Quote Originally Posted by 99PontTA
    At least I can spell.
  1. Two WS6 Questions. Rear End Clunk & Jacking Up Front End.
    By Redrokit8 in forum Firebird / WS6
    Last Post: 11-25-2011, 05:37 PM
  2. clickity clunk from rear centre when slowing down
    By 5abivt in forum General Help
    Last Post: 09-22-2009, 06:20 AM
  3. Rear End Clunk
    By One_Bad_TA in forum Drivetrain
    Last Post: 10-23-2008, 09:35 AM
  4. Help: Clunk in the rear end?
    By GOR1LA in forum Suspension and Handling
    Last Post: 05-09-2008, 07:02 PM
  5. *Clunk*? Tranny? rear end?
    By gimmeadonut in forum Automatic Transmission
    Last Post: 07-24-2007, 08:20 PM
