    Dec 2008
    Anderson, SC
    Metallic Red/Charcoal
    2000 Z28
    Dyno tuning & 4L60E W/TCI stall converter
    How reliable are the numbers im getting. Mild build & Blown 5.3L 469.5 HP/449 Torque @ RW
    1st considering it's hard to get up power & RPM with out down shifting out of drive. 2nd in theory the converter is not locked up while making a pull (although something does happen @ about 5,800 because power & torque abruptly drops off @ that point then levels off) @ 5,800 torque is falling but HP is headed toward about 500 @ 6,000 when it abruptly drops.
    Any ideas out there?
    Dec 2008
    Anderson, SC
    2000 Z28
    Probably shoulda called TCI to start with.
    mercersburg pa
    hugger orange
    2004
    first off I'm no pro.
    if you are using hptuners, you should beable to go into RTT (real time tuning)- transmission setting and make your converter lock and force it to stay in the gear you want
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    You should be running it in 3rd on the dyno, that is 1:1 ratio of the tranny.
    Dec 2008
    Anderson, SC
    2000 Z28
    Thanks.
  1. tuning stall converter 2010 camaro 6.2
    By hebronchief in forum Drivetrain
    Last Post: 09-30-2011, 07:52 PM
  2. Chassis-Dyno Tuning - Dyno-Mite!
    Last Post: 01-28-2011, 02:30 PM
  3. Question: Stall Converter
    By one_fast_z28 in forum Automatic Transmission
    Last Post: 11-28-2010, 07:48 AM
  4. Replies: 15
    Last Post: 07-02-2007, 01:49 PM
  5. Stall Converter Help
    By Tonys99RamAir in forum Automatic Transmission
    Last Post: 10-15-2005, 08:48 AM
