Thread: power steering
01-03-2009, 12:39 PM #1
power steering
I need help with a steering problem... when i first start my car and begin driving my steering is fine but once the car warms up to normal operating temp its like i have no power steering. my rack and pinion was leaking so i replaced that but i still have the same problem...any ideas? maybe power steering pump?
01-04-2009, 05:46 AM #2
Did you bleed the system after the rack instail?
Hows the fluid level?
Any leaks now?
When it feels like you have no powerstearing, Try giving it some gas, in neutral and turn the wheel at the same time, does that help any?
01-10-2009, 12:43 PM #3Crazy Canuck !
- Jun 2002
- Montreal, CANADA
check if any of your lines touch your headers... maybe boiling the thing unvoluntarily.
Eugenio_SS
01-12-2009, 11:07 AM #4
So no leaks thers plenty of fluid and when i do turn in nuetral while revving it works fine ill check on the header thing this weekend thanks
04-08-2009, 01:31 PM #5Junior Member
- Mar 2009
- pennsylvania
red- 98 trans am
can the rack and pinion be replaced from below without pulling motor? mine is leaking pretty bad and have to order new
04-08-2009, 02:19 PM #6
04-08-2009, 02:20 PM #7
btw...i bought a new pump and no problems now
Help: Power steering
By 1998ss in forum Stereo and ElectronicsReplies: 1Last Post: 09-17-2013, 04:02 AM -
I need power steering help
By transam_00 in forum External EngineReplies: 14Last Post: 01-11-2011, 08:51 AM -
Question: Power Steering, Manual Rack, Power Steering Pumps-etc
By TerribleTed in forum General HelpReplies: 2Last Post: 11-18-2010, 05:37 PM -
power steering is no more
By transamgirl89 in forum Camaro / SSReplies: 4Last Post: 08-20-2010, 07:27 PM -
power steering?
By Spikito in forum Camaro / SSReplies: 2Last Post: 06-19-2009, 11:51 PM
