Results 1 to 10 of 10
Thread: Any suggestions
    Junior Member 2000ssturd's Avatar
    Jan 2008
    Portland, OR
    Bright Red
    2000 Camaro
    Any suggestions
    Ive got a 78 cutlass with a 455 thats been sittin for about three years and im gonna be gettin it on the road again. Besides a battery and some good gas, anyone have some suggestions on what I might need to get it running to get it to my shop. Do you think the gas is still gonna be liquid or would it be gummed up already? Replace plugs?? Ignition module(HEI)?
    Carless blkSS98's Avatar
    Jan 2008
    Eastsound, WA
    looks like you already touched everything. Gas is real likely to be bad, my want to check the fuel filter too.
    Senior Member SS02's Avatar
    None
    Gas is toast forsure!!!!!!
    Check all fluid levels, and change plugs...
    See if it fires and then go from there.
    Feb 2006
    2002 WS6
    Yeap drain the gas, flush the carb and check the rest of the fluids. Also pop the wheels off and make ssure all is good with the brakes and no critters have set up home.
    Junior Member slp1122's Avatar
    Nov 2008
    oc/las vegas
    pewter
    2000 camaro ss
    i would change the oil as well
    Jan 2008
    Portland, OR
    Bright Red
    2000 Camaro
    Thanks guys, Ill see what I can do once the snow clears.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Priming the oil system wouldn't hurt either.
    Jan 2008
    Portland, OR
    Bright Red
    2000 Camaro
    Good idea, thanks
    IL
    06 HD Softail
    1998 Trans Am m6
    check for dry rotted hoses and belts
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    someone said check for critters make sure you do that before starting I didn't when i started my old c10 after a year of sitting and I had fun with a mouse
  1. V6 suggestions??
    By babynate18 in forum V6
    Last Post: 03-22-2009, 06:27 PM
  2. New SS, Need suggestions.
    By Muscle in forum Camaro / SS
    Last Post: 05-15-2007, 05:21 AM
  3. wax suggestions???.......
    By clg82 in forum Showcar and Detailing
    Last Post: 05-03-2007, 06:40 AM
