Thread: rear end noises?
12-11-2008, 07:00 AM #1
- Nov 2008
- Northern Utah
Metallic Blue- 94 Z28 A4 T Tops 52K MINT
rear end noises?
I have a 94 Z28 A4. And recently it has started to make some weird nosies when turning. It does it worse in reverse turning left. I flushed out the rear end about a month ago and used Amsoil 75w90 syn severe gear oil/w slip lock additive. It's odd that it just started to make noise a month after the fluid change.
This car I bought from orignal owner and has not been driven hard at all. It only 52K on it as well as being bone stock. Could it be that I am driving it alot more now? Any help would be great. Thanks.
Scott.
12-11-2008, 01:22 PM #2
you put in the GM slip additive right? I heard that's the only stuff that does the job. Also, check your torque arm bushings, and drive shaft U joints. Is the rear leaking and if so how much?
12-12-2008, 06:17 PM #3
Newer SAE J306
As of June 2005 there have been some redefined classifications to the SAE J306 Automotive Gear Oil Specifications.
Under these new limits, it is permissible to use 75W-110 gear lube in the place of 75W-90 gear lube in order to attain the correct gear lube viscosity of at least 19.5 cSt @ 100C.
That’s probably not what you wanted to hear after spending hard earned coin on the 75W-90 lube, but the 110 lube will give you the oil viscosity GM originally required for your differential.
Hope this helps,
CompSyn
12-20-2008, 03:55 AM #4
75W-110 in place of 75W-90...
Below, an original personal message from My94ZZZ to CompSyn regarding differential noises.
Originally Posted by My94ZZZ
12-20-2008, 01:11 PM #5
hey comp you got the write up on that info???
12-20-2008, 04:27 PM #6
2005 SAE J306 write ups...
TransAm11973,
Initially I didn’t provide the links like a normally would because the best source I found where you don’t have to pay for the info, is through a company that makes oil additives. And of course you know that Amsoil does not recommend the use of oil additives with their motor oils. So it was a conflict of interest of sorts. But since you asked nicely, I’ll take you right to the sources…
Helpful write up on SAE J306
SAE J306 Abstract
Enjoy,
CompSyn
12-20-2008, 08:22 PM #7
thanks man i was just curious...i am already a amsoil freek but thought i would read up. thanks again
Car noises?
By Meezy in forum Firebird / WS6Replies: 5Last Post: 04-29-2011, 01:11 PM -
noises
By kenro23 in forum General HelpReplies: 9Last Post: 03-04-2011, 01:47 PM -
Noises
By Retired Cop in forum General HelpReplies: 18Last Post: 03-26-2009, 01:28 AM -
Rear-end noises
By dadowd in forum Suspension and HandlingReplies: 1Last Post: 02-15-2009, 11:59 AM -
Noises, Noises, Noises. PLEASE help.
By Secret Formula in forum Firebird / WS6Replies: 29Last Post: 02-02-2007, 09:57 PM
