Results 1 to 10 of 10
Thread: noises
02-28-2011, 03:04 PM #1
noises
my mechanic took off my EGR and A.I.R. hoses. the pump for the A.I.R. is still in and when i start my car it obviously makes an crazy noise. how can i stop this noise or disconnect the pump all together?
02-28-2011, 05:30 PM #2Senior Member
- Apr 2008
- Madison, WI
Unplug the pump or remove the fuse. well, really you should just remove the pump all together.
02-28-2011, 09:25 PM #3
[QUOTE=Cutlass;2584320]Unplug the pump or remove the fuse. well, really you should just remove the pump all together.[/QUOT
as simple as that? nothing else needs to be done besides that pump?
03-01-2011, 01:28 AM #4Member
- Cedars, Pa
White- '02 Camaro SS
03-01-2011, 05:26 PM #5
03-03-2011, 12:24 PM #6
03-03-2011, 12:25 PM #7
03-03-2011, 02:08 PM #8
is pretty easy kenro. just pull the fuse in the fuse box in the engine compartment. on the driver's side underneath the bumper there is the access door that access the parking lights. It has 2 10mm bolts. Loosen them up, open the plastic door and you will see the pump. Unplug the electrical plug and disconnect the rubber hose that comes from the top. The whole pump has 4 bolts holding it to the frame. take those 4 bolts and the pump comes out.
03-03-2011, 03:28 PM #9
I took the AIR pump crap out of both my f-bodies. Looks much cleaner under there. My SES light is on the one that isnt tuned and is a weekend driver. This doesnt affect driveability, gas mileage or anything does it? I am going to get it tuned when I put headers on there but seems pointless to have it tuned at this point.
03-04-2011, 01:47 PM #10
No need to tune it just for removing the AIR, unless the Check engine light bothers you. Pull that fucker out.
Car noises?
By Meezy in forum Firebird / WS6Replies: 5Last Post: 04-29-2011, 01:11 PM -
Noises....
By The_Wretched in forum Manual TransmissionReplies: 1Last Post: 12-01-2009, 11:04 PM -
Noises
By Retired Cop in forum General HelpReplies: 18Last Post: 03-26-2009, 01:28 AM -
Noises, Noises, Noises. PLEASE help.
By Secret Formula in forum Firebird / WS6Replies: 29Last Post: 02-02-2007, 09:57 PM -
noises?
By Canes2413 in forum General HelpReplies: 3Last Post: 09-15-2005, 10:21 PM
