    frankthetankjfpc
    Guest
    Hellpp With Starting!!!
    I own a 1998 camaro ss. all is well aside from the fact that it is difficult to get it started every now and then. I have to play around with the key in the ignition to get the starter to catch. Hopefully, after enough fiddeling around the silenoid decides to kick over. Pleasseeee help me with any ideas as to what this may be!
    Lost in Texas
    Custom Slate Blue
    99 B4C
    make sure your VATS is working it could just be your key resistor, otherwise the whole ignition switch could be going out
    frankthetankjfpc
    Guest
    Im sorry bro.....i bought my ss about a week ago, and still learning specifics of the vehicle. what exactly is the VATS?
    frankthetankjfpc
    Guest
    do you think it could possibly just be a faulty connection? i also notice that the ignition switch is not securely fastened to the steering column.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    that could very well be your problem. the vats is the anti theft system, the resistor in your key
    Lost in Texas
    Custom Slate Blue
    99 B4C
    ill explain more after I run to unlock a car, I'm workin
    frankthetankjfpc
    Guest
    If i push the ignition switch inward, and gently turn the key it will start.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    you found your problem
  1. ss starting to age
    By slimss in forum Camaro / SS
    Last Post: 01-31-2013, 12:32 PM
  2. Question: Starting
    By travis20 in forum Internal Engine
    Last Post: 12-27-2011, 11:41 PM
  3. Starting over
    By B4C Camaro in forum New Member Introductions
    Last Post: 06-17-2009, 08:30 PM
  4. Not Starting?
    By BlueMagicSS in forum General Help
    Last Post: 10-17-2008, 04:09 AM
