Results 1 to 13 of 13
    USMC Y2K_CAMARO's Avatar
    Rocky Point, NC
    Exclamation Problem w/ dash lights after tire/rim change
    I have had no problems with my car at all. It is a 2000 Camaro Z28 M6 with 66,500 miles. Maybe its just a coincidence that it happened after a tire/rim change, but I'm giving you all info. I had 18" rims with 245/40's on the front, and 275/35's on the rear. I just changed them out for 17" rims with 245/40's on the front and 275/50's on the rear. Now, at start up, everything is fine, but once I get at a steady speed of over like 35-40mph, the following lights come on, "ABS INOP", "ASR OFF" (but traction control still works, and cant be turned on or off while "ASR" light says its off), and the "BRAKE" as in the E-brake is up. I can turn off the car, then back on and lights are not on, but then I reach that certain speed again and they come back on. I have tried disconnecting the battery, but that didn't do anything. I haven't had codes read yet, I know its throwing a code because I have no cats, but I haven't checked it to see if it's throwing anything else. Please, any idea's?
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Sounds like you have a difference in diameter from front to rear and your sensors don't like that with abs and traction control. factory SS is 275/40/17 all around 25.7" I think. 245/50/16 on a Z28 but same height. Your numbers posted don't seem correct?
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    Quote Originally Posted by SSTODD View Post
    BINGO!!!, This is what happens when you have a difference in the diameters of the tires on the vehicle, I am running 285X35XZR18 all the way around, and have no issues with the ABS (I do not have traction control).
    When there is a difference in the rolling mass the ABS system reads it as the tires are slipping.
    SteveC
    Rocky Point, NC
    Quote Originally Posted by SteveC View Post
    SteveC
    Well what about the difference in the tires when I had the 18's on the car? I had no problems then
    LIVONIA,MICHIGAN
    PEWTER
    you had 40's on the front and 35's on the rear so the height was probably close. now you are too tall with 50's in back. you need to look at a manufacturer tire chart for your sizes and see the diameters of each. the first number is the width (275) but the 35,40,50 affects the height.
    Rocky Point, NC
    Ok, but I can just get it calibrated for the bigger tires right?
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    You need to have the same tire OD all the way around.
    SteveC
    LIVONIA,MICHIGAN
    PEWTER
    I've never heard of a 275/50/17 for our cars? Check your numbers again, but if you go narrow in front the aspect ratio needs to be bigger (50) and the wider rear needs to be (35, or 40) so the OD is about the same. See tirerack.com and look at specs of tires and the diameters.
    Rocky Point, NC
    That number is correct. A 275/50/17 M&H drag radial
    LIVONIA,MICHIGAN
    PEWTER
    WOW, that is a tall tire, you may need a (60 or 70) series up front to match that diameter in the rear.
    Rocky Point, NC
    Yea, or I could just put the other rims and tires on there for when I drive on the street
    Member 01 SS Vert's Avatar
    May 2008
    Knoxville, TN
    01 SS Vert
    I have this same issue:
    275/40/17s Front
    315/35/17s Rear
    I just did a thread on my problem. Anything I can do without changing tires? It's even happened with 275/40s on all 4 corners, so I'm stumped.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Y2K CAMARO,
    245/40R18 is 25.7" tall
    275/35R18 is 25.6" tall
    Close enough
    245/40R17 is 24.7" tall
    275/50R17 is 27.8" tall
    NOT close enough, there's your problem
  1. Help! Dash lights off & when headlights on radio lights off
    By BlackWS6TA in forum Firebird / WS6
    Last Post: 07-20-2012, 11:39 AM
  2. Replies: 0
    Last Post: 09-07-2010, 05:25 AM
  3. No running lights, dash lights
    By 77k5 in forum General Help
    Last Post: 01-07-2010, 12:35 PM
  4. Handling change w/ tire change
    By hotdog453 in forum Wheels and Tires
    Last Post: 06-17-2008, 07:17 PM
  5. wtb dash lights
    By DW2000TA in forum General Classifieds
    Last Post: 04-15-2006, 05:27 PM
