Results 1 to 10 of 10
Thread: Coils
    T/A=LOTS of Vagina =X
    Sacramento, Ca
    Dark Blue
    98 Trans Am =]
    Coils
    hey guys im a broke hs student and i was thinkin bout lowering my car..is it ok to just cut the coils?? will it hurt anything or lose handling? has anybody done it on here if so how is it?? let me know please
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    not a good idea to be honest. I've seen a lot of things go wrong like actually cracking your springs and bottoming the car out.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Quote Originally Posted by Redphoenix1998 View Post
    What he said...cutting is a bad idea.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Definetly wouldn't cut them, for reasons already posted.
    There is an old school technique I've been told about, but I also wouldn't recommend it. Use a blow torch and heat up a small section of the coil until it's hot enough to bend then have some buddies add a little weight to your car.
    I DO NOT RECOMMEND THIS EITHER.
    Member ebdboudreaux's Avatar
    Nov 2008
    Tampa, Fl
    99' 30th Ann TA
    definitely not... I've seen many ppl take that route and it NEVER turns out good... might seem ok at first, but their cars always ended up being f'ed up
    Member transAMchubby's Avatar
    St. Louis, MO
    '99 Trans Am
    if you want to test drive my DD '96 Escort with a broken coil youre welcome to it...just to see what its like. just dont go over 15mph (its not really my DD again until the strut assy gets replaced)
    what happens when you hit a pot hole?
    Member screaminbird's Avatar
    Aug 2008
    Aurora, Illinois
    White/Gold
    99 T/A sold/67 Firebird
    dont heat that coil if that comes out by mistake u better duck ive personally seen my friend get a broken nose cause he didnt know what he was doing and didnt want my help
    Senior Member Rhinohuey's Avatar
    Glendale, AZ
    1999 Trans Am
    like everyone else already said...cutting is a bad idea.
    If you do decide to cut them though, I would recommend using something that can slice through fairly quick like a portaband or something. From what I've heard its the heat that cutting causes that is bad for the spring since they are heat treated. The spring rate gets messed up and can cause cracking, etc
    Nov 2008
    Tampa, Fl
    99' 30th Ann TA
    The problem with cutting them is you're taking away from their performance... They're designed to that certain length to absorb so much pressure/weight... If you cut their length down, its gonna bottom out and just continue to get weaker from there... then you'll be bouncing all over the road... And I'd probably shake my head and laugh like I do when I see the rest of the cars on the road like that....
    Member chuck4345's Avatar
    memphis tn
    2002 trans am ws6
    Quote Originally Posted by Mike's TA View Post
    did this to truck before baddddd idea makes springs weak and will beat u to death on the ride plus cost me more money to have some fix my mistake by doing it right
  1. Question: LS1 coils versus LS3 coils
    By Bobbyd9083 in forum External Engine
    Last Post: 06-24-2012, 06:11 AM
  2. Msd coils
    By JELSWON in forum Parts Wanted / Trade
    Last Post: 12-30-2009, 04:27 PM
  3. Wanted: GM Coils
    By IcantDo55 in forum Parts Wanted / Trade
    Last Post: 10-27-2009, 09:17 AM
  4. Question: Coils
    By james schofield in forum External Engine
    Last Post: 12-16-2008, 06:24 AM
  5. Help: 98 coils on 99 LS1
    By cmcdonald in forum General Help
    Last Post: 04-01-2008, 07:52 PM
