Results 1 to 20 of 27
Thread: Let's See your Pod Gauges
11-04-2008, 08:10 AM #1
- Jun 2008
- In the Sticks, TN
Black- 2002 Camaro SS
Hey guys, just interested in seeing what set ups you have with your pod gauges. Post some pics up. Thanks!
11-05-2008, 01:36 AM #2
- Dec 2005
- Laurel, Maryland
11-06-2008, 08:49 AM #3
- Jun 2008
- In the Sticks, TN
Thanks ls1Camino, ^^ Beautful T/A you've got there.
11-07-2008, 07:37 AM #4
- Jul 2006
- Ocean Springs, MS
TRIPLE BLACK- 2002 WS.6 Build #12425
Here ya go, day and night.
11-07-2008, 11:55 AM #5
11-07-2008, 06:52 PM #6
- Jun 2008
- In the Sticks, TN
Haha!, well good luck man hope all goes well!!!
11-08-2008, 05:03 PM #7
- Sep 2007
- Colorado
Black- RIP S4 06Tbss
11-11-2008, 09:13 AM #8
- May 2006
- Canada
Blue 1997 Trans Am(Sold)- Pewter 2001 Trans Am Vert
does anyone supply a tripod A-Pillar for convertible TA's?
11-11-2008, 11:26 AM #9
11-13-2008, 08:54 AM #10
- Jun 2002
- Montreal, CANADA
Eugenio_SS
11-14-2008, 01:25 PM #11
11-14-2008, 02:32 PM #12
I just installed an A pillar tri-gauge pod on my T/A. One of them is a electric fuel pressure gauge and came with a sending unit to hook into the fuel rail. I've been trying to find out where it goes but haven't found it. Tech support said I had to buy an adapter that would allow it to thread to the schrader valve. Has anyone hooked up an electrical fuel press. gauge? And if so could you tip me off on how to do this? Also a trans temp gauge, where does that hook up to? I know on the transmission but where?
11-14-2008, 05:43 PM #13
Fuel gauge cant help you.
Transmission is easy. Just drop the pan and drill a hole in it to put a drain plug fitting into. Then your sensor screws in to that. Here's a hot tip. I put mine in the bottom in an area away from any moving parts. What I should have done was mounted it in the back side of the pan. That way you don't lose any ground clearance. I'm always paranoid about driving over something and ripping it out but so far 9 years and 42k later I still haven't done it. One of these days I'll just replace the pan and do it right.
BTW I have the triple gauge set up. I put switches next to each gauge in the pod. When I wired them in each gauge becomes dual purpose.
Oil temp does both oil and transmission.
Fuel mix does left and right bank.
Head temperature does left and right bank.
Sorry no pictures handy. Trust me. It's nice.
11-14-2008, 07:44 PM #14
- Thornton, CO
Ignore the factory gauges...car didn't have a computer (or motor) when I took the picture.
11-14-2008, 09:19 PM #15
11-15-2008, 03:47 AM #16
11-15-2008, 05:24 AM #17
I just went to Radio Shaft and bought 3 of the smallest DPST switches with bat handles I could find. Wired them up before the gauges and after the signal source. The computer has a seperate left and right bank so you need two wires from there. Just make sure your banks match for A/F mixture and head temperature. The head, oil and tranny are single sources. Just just wire them whichever way makes sense to you and I'm talking about left and right throw of the switches.
I wish they made a gauge pod for the passenger side. I see a company called Glowshift has a generic for that but I haven't tried it and I doubt the angles would look identical but reversed to the ones we have now. They are only $18 so I may try it just for grins.
11-15-2008, 05:44 AM #18
12-15-2008, 06:08 AM #19
One during the day and one at night....
Auto Meter Cobalt -- Nitrous Pressure, Fuel Pressure and Wideband O2.
Sorry for the crappy picture quality.
2002 Camaro SS M6, 2.5 PRC 5.3L heads, TFS 228/230 cam, FAST 92, bolt ons + a 10 lb bottle in the back.
1989 Corvette L98, A4, Full bolt ons, etc.
12-16-2008, 06:58 PM #20
Look in this picture right above the red wiring to the TB, there is a blue fitting, thats where it goes, its the front of the fuel rail on the drivers side, there should be a test port there, should take a cap off and the thread your fitting there, assuming they gave you one?!?
gauges
By JoshuaGrooms83 in forum Forced InductionReplies: 17Last Post: 02-08-2011, 12:30 PM -
Gauges
By jamessr in forum Stereo and ElectronicsReplies: 0Last Post: 08-11-2009, 12:57 PM -
Phantom Gauges,white Gauges(lt1),gauge Pod
By onefastbird! in forum Parts Wanted / TradeReplies: 2Last Post: 11-19-2006, 03:20 PM -
New Gauges
By CYCLONE GREY GTO in forum GTOReplies: 9Last Post: 10-23-2006, 10:00 PM -
any have gauges
By ls1marine in forum Western MembersReplies: 4Last Post: 08-22-2006, 08:35 AM
