Results 1 to 18 of 18
Thread: gauges
01-20-2011, 11:36 PM #1
gauges
well im slowly getting my car preped for turbo and want to make sure i get all the right guages for it. So far Ive decided that a vac/boost gauge in PSI, a digital F/A guage with wideband senor and maybe datalog capability, and for good measure since im getting a stall, a tranny temp gauge. Already picked out the ones i want. THey match the interior very well. Gonna run a triple A-pillar pod. I was wondering if i need any other? DO i need a fuel pressure or a oil pressure (near the turbo) gauge? Im getting these guages for actual funtioning reasons and monitoring, not for show.
Heres the ones i want
Triple pillar pod
Trans Temp gauge.. Id get it in red colors can be changes
Boost gauge.. also red.. colors can be changed too
A/f Guage.. not sure which to get. both have wideband and datta log capability. I like the one in red though
01-21-2011, 01:44 PM #2
Make sure you get a high quality wideband set up. The Innovate Lc-1 is top notch in my opinion. I would not trust a "glow shift" guage to tell my if i suddenly go lean. The dynojet models are also very nice.
01-21-2011, 01:48 PM #3
whats wrong with glowshift widebands?
01-21-2011, 01:57 PM #4
Ive never heard of anyone using one, so i dont really have anything negative to say against them. But the innovates are very accurate. And accuracy is key for tuning and knowing if something goes wrong.
01-21-2011, 02:03 PM #5
this is what comes with the A/F guage im considering right now. this is the one without data log. But theres this one and then one with data logging.
52mm (2 1/16 inch) black face with magnified lens
3 Color LED range indication and a 3 digit LED active numeric display
Digital 12 volt Wideband Controller Unit
Bosch LSU 4.9 Wideband Oxygen Sensor
13 ft. Sensor Wire Harness
16 ft. Control Unit to Gauge Wire Harness
5 ft. Power Wire Harness
Weld- In Sensor Bung
Mounting and Installation hardware
1 Year Warranty & Free Technical Support
01-21-2011, 02:05 PM #6
Give it a try. whats the cost.
01-21-2011, 02:17 PM #7
189.00 without datalog
199.00 with datalog
01-22-2011, 10:41 AM #8
I do like the red gauge from innovate. they are about the same price i noticed.
01-23-2011, 07:38 AM #9
02-06-2011, 08:09 PM #10Member
- Apr 2008
- Tucson
Psycho Therapist- I take "the" out of
you will need a fuel pressure guage. Also if you can I would get a tru boost gauge. it measures your bost level, and you can change the boost level as well. I will be running glowshifts with my new set up. never heard anything bad about them, the people that do run them like them.
02-07-2011, 05:43 AM #11
02-07-2011, 06:45 AM #12
Well my trans temp gauge is here. gonna do a vent gauge install. Waiting on a speedinc gauge adaptor to fit it in tight.
02-07-2011, 09:47 AM #13
Trueish. i would get a fuel pressure guage if youre running after market pumps or an adjustable regulator. you can set the regulator if you cant see what psi you are. just get one that stays under hood and goes into the end of the fuel rail. maybe 20 bucks and itll take 5 minutes to install cuz you dont have to run any lines or wires
02-07-2011, 10:27 AM #14Senior Member
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
I think a really good wideband gague (if your willing to spend the coin) is the Autometer Nexus Wideband Air/Fuel Ratio PRO Wideband A/F Kit $299.99 and here's some of the stats on it:
Includes 8 ft. tubing or wiring harness.
LED digital display.
Requires purchase of Sensor Module, Model #6400 or #6401.
Includes custom tuned .1 AFR Resolution Bosch LSU4.2 Sensor
Display data in Lambda or numerical A/F ratio
User programmable range
Peak recall/memory
10:1 to 20:1 AFR Range for Gasoline Applications
Adjustable for Alternate Fuel Types (Ethanol, Methanol, Propane, CNG)
6:1 to 18:1 AFR Range for Alternate Fuel Types
User Programmable Warning Function
From the #6400 or #6401 modules u can download the data right to your laptop and review it which is a nice feature.
02-08-2011, 05:40 AM #15
^^^ the problem with that setup it you also have to buy the whole nexus control module. i had looked at those guages cuz i like the way they look but theyre all wired into one central hub. and the module is like 400 bucks i think.
02-08-2011, 07:47 AM #16
holy cow, thats a bit much for some gagues but im sure they are worth it if you need em for slightly more extreme setups.
02-08-2011, 10:15 AM #17Senior Member
- Sep 2005
- New York, NY
I believe the 6400 and 6401 modules (the control modules for the Nexus Gauges) are like $199 if im not mistaken........BUT........ If your going to do a triple A-pilar gauge setup with 3 Nexus gauges and the control module your looking at like ~$900 for gauges which is a bit nuts... I have to agree with Joshuagrooms83 in saying that those gauges are more for an extreme setup car or for those who like to burn Benjamins!
02-08-2011, 12:30 PM #18
they are nice looking guages though. i originally wanted them until i realized what the cost would be
Gauges
By jamessr in forum Stereo and ElectronicsReplies: 0Last Post: 08-11-2009, 12:57 PM -
Gauges
By tims02 in forum CorvetteReplies: 2Last Post: 06-12-2008, 08:30 AM -
Phantom Gauges,white Gauges(lt1),gauge Pod
By onefastbird! in forum Parts Wanted / TradeReplies: 2Last Post: 11-19-2006, 03:20 PM -
New Gauges
By CYCLONE GREY GTO in forum GTOReplies: 9Last Post: 10-23-2006, 10:00 PM -
any have gauges
By ls1marine in forum Western MembersReplies: 4Last Post: 08-22-2006, 08:35 AM
