Thread: pinion seal
10-08-2009, 07:37 PM #1
pinion seal
What should I torque my pinion seal down to? And is ok to fill the tranny by the shifter hole?
10-09-2009, 07:07 AM #2
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
check your blinker fluid and your muffler bearings too
10-09-2009, 08:09 AM #3
Yes, you can fill the trans through the shifter hole.
I'm assuming you're talking about torquing the compagnion flange nut when you say "torquing the pinion seal".
The nut needs to be torqued so that the crush collar compresses and the pinion bearing preload is 10-15in/lbs for used bearings, or 15-30in/lbs for new bearings. Pinion bearing turning torque is checked with an inch pound beam style torque wrench.
10-09-2009, 08:24 AM #4
10-09-2009, 09:23 PM #5
10-10-2009, 12:23 PM #6
I counted the threads and make 3 inline peen marks on the flange, nut and gear.
09 Vulcan 900 custom.
2007 Subaru Legacy 2.5i
1998 Z/28 Hardtop A4 | Y2K wheels | SLP Lid | Magnaflow catback |cutout | Hotchkis LCA'S/PHB | BMR TA and D/S Loop| Tuned by Frost....300rwhp/308rwtq
97 Cobra- bolt ons | full exhaust| 4.30's| suspension | SCT tune- sold!
Pinion seal.
By goof4080 in forum DrivetrainReplies: 3Last Post: 06-21-2012, 06:09 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 15Last Post: 08-03-2011, 04:56 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 5Last Post: 04-23-2011, 07:46 PM -
pinion seal
By AF1Strider in forum DrivetrainReplies: 5Last Post: 04-08-2007, 01:23 PM -
Pinion seal
By jimmy77611 in forum DrivetrainReplies: 25Last Post: 03-10-2007, 05:51 PM
