Results 1 to 2 of 2
09-04-2012, 10:12 PM #1
- Aug 2012
- Vancouver
Swapping open rear end to limited slip disc brake
So I am putting the whole rear end out of an auto v8 in my 3.4l 5 speed what should that do to my 5 gear freeway rpm range and also do u have to change anything out as far as break lines,abs system? Or should it just bolt on and be good to go with my stock system? Doing this swap tomorrow so any anwsers asap
09-07-2012, 06:10 PM #2
You will have to change everything. Your current axle is a drum brake setup. No v8 4th gen cars came with drum brake rears..iirc
Second without knowing what the axle ratio differences are there's no viable way to determine engine rpm at a given speed.
Sure it will bolt up, but the year and options for ABS and traction control will matter, all 4th gen 3.4 cars are 3 channel rears.
But not all 3800 cars are, however most are 4channel like the z and ss cars after 98..
Your speedo will need recalibarated for the new gear set whatever that maybe as well.
The LT1, LS1 and 3800 rears are also different in that the LT rear will have an external parking brake mechanism.
Where as the LS and and 3800 cars from the same years will have an internal parking brake setup which is inside the rotor disk.
Also your 3.4 has a split drive shaft or 2 piece and the LS1 and 98 thru 02 3800's are one piece drive shaft cars.
Rear end fluid change. Limited slip additive ?'s
By RPO_WU8 in forum General HelpReplies: 6Last Post: 09-27-2009, 08:23 AM -
For Sale: Hawk Performance Front and Rear Disc Brake Pads
By WS6ICK in forum Parts For Sale / TradeReplies: 2Last Post: 07-11-2009, 01:57 AM -
Eaton Limited Slip
By robert 98 in forum DrivetrainReplies: 2Last Post: 03-09-2008, 01:06 PM -
Limited Slip Not Working?
By gearhead1 in forum DrivetrainReplies: 11Last Post: 03-05-2007, 04:21 PM -
2000 A4 WS6 -- How do I know if I still have limited-slip??
By ScrapMaker in forum DrivetrainReplies: 2Last Post: 02-06-2006, 09:54 AM
