Results 1 to 14 of 14
Thread: OBD2 Codes -- Where to start
03-08-2008, 03:05 PM #1
- Oct 2007
- Indiana
Pewter- 2001 Trans Am
Ive posted before about my car and some of the problems its having i bought a cheap code scanner today that gave me some codes. Heres what I found in priority coded order, now where should i go from here?
P1133 HO2S Insufficient Switching Bank 1 Sensor 1
P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0757 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear (( Which explains why half the time my car wont shift into 4th gear AT))
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P1153 HO2S Insufficient Switching Bank 2 Sensor 1
P0134 "(pending)" not sure what that means
Now this is before i did a reset on my car i cant remember how to reset the codes but im about to look it up on the net. As I havent changed anything lately I figure these are probably the most recent. Question is where do I start? Where are these banks and sensors im not sure which O2s these are or rather located physically on the car.
03-08-2008, 03:23 PM #2
For starters, check out this site:
http://www.gearchatter.com/
03-08-2008, 03:26 PM #3
Secondly, I'd look at your harnesses @ the PCM because there are just too many codes to be a simple problem. Might be a common ground problem too...
-Eagle
03-08-2008, 03:31 PM #4
- Oct 2007
- Indiana
Ok so im dumb because i didnt realize the the erase on this handheld would clear the PCM i thought it just cleared the hand held but hey what ever... I drove down the end of the block and back got no SES light not sure how long i have to drive before it starts to fail. Maybe tonight when i go home from work i'll get a better idea.
But where is bank 1 & 2 sensor 1 on the car because if those are the ones right under the floorboard i think the harnesses may be damaged. Are those the ones?
03-08-2008, 03:35 PM #5
- Jul 2005
- Jacksonville, FL
Yeah start with gearchatter. For the 02's bank 1 is drivers side, bank 2 is passenger side - sensor 1 is precat, sensor 2 is postcat. Don't think gearchatter lists trans codes, I'll post a link for it.
03-08-2008, 03:37 PM #6
The codes won't throw until you've cycled the ignition at least 2 times, sometimes more if the condition isn't met 2x in 2 ignition cycles.
That's also what that "pending" means in your codes. Means its occurred once, but not enough times to throw a SES light.
-Eagle
03-08-2008, 03:51 PM #7
- Jul 2005
- Jacksonville, FL
Don't completely understand it, but here's a link for P0757: www.ls2.com/boggs/a4/DTC%20P0757%205.7.htm
03-08-2008, 04:20 PM #8
- Oct 2007
- Indiana
I have no cats... =)
Pretty sure its illegal but dont tellLast edited by SilentTrouble; 03-08-2008 at 04:28 PM.
03-08-2008, 05:00 PM #9
- Oct 2007
- Indiana
Ok so i need to take care of the O2 sensors but can anyone tell me anything about that Transmission Solenoid... can they be replaced? Are they expensive? Does the tranny have to be pulled out of the car and taken apart? Any of this would be good to know
03-08-2008, 05:47 PM #10
03-08-2008, 08:58 PM #11
- Oct 2007
- Indiana
PMs? I have no board messages
03-08-2008, 10:07 PM #12
pm Performabuilt with your tranny questions.................I replaced some solenoids on mine
prices range from $30-75...............you just take the pan off and the solenoids are there, some have a pin that slides over them and holds them in
03-09-2008, 04:56 AM #13
03-09-2008, 03:21 PM #14
- Oct 2007
- Indiana
Eagle i got your message there. and Thanks for that picture i got it changed out today. was fairly straight forward. I cleared the codes last night and drove my car several times today running errands several starts, stops, and about 25 miles in one trip and now i still have no codes. So Im still waiting to see if they pop up
Cold Start Up & Codes P0300, P1416, P1683
By ChrisWS6 in forum General HelpReplies: 19Last Post: 07-10-2018, 05:59 AM -
Question: Air pump at start up codes p0430 p1415
By BlCk02WS6 in forum General HelpReplies: 1Last Post: 08-08-2014, 12:31 PM -
Help: OBD2 codes for 2000 camaro z28
By rafael707 in forum General HelpReplies: 5Last Post: 05-01-2012, 05:41 PM -
need obd2 help please
By brownie98 in forum Computer & TuningReplies: 4Last Post: 07-12-2008, 07:44 PM -
Need Help With Obd2
By SWEETZ in forum General HelpReplies: 3Last Post: 08-28-2007, 06:25 AM
