Results 1 to 20 of 24
Thread: Need new MAF sensor??
06-11-2008, 10:50 AM #1
I have a 2000 Trans Am WS.6 and at around 2500RPMs usually under around half throttle but would do it at different amounts of throttle at different times. the car seems to cut off for a second then runs fine. There are no other running problems. Is there a way i can check this? Or if this sounds like the sensor is bad, how much should i look for a new one and where? Thanks for any help
06-11-2008, 11:39 AM #2
- Jul 2005
- Jacksonville, FL
What makes you suspect the MAF? Is the car throwing any codes?
06-11-2008, 11:47 AM #3
- Jan 2006
- Shepherd, Michigan
most of the time if it is maf sensor related..you would throw the ses error of low or no voltage input for the maf. I would try to use some maf cleaner on it first.
06-11-2008, 12:02 PM #4
- Thornton, CO
Doubt it is the MAF.
I would bet on ignition. Fuel filter clogged a little, spark plug gap off.
Mods? Ever been tuned?2008 Trailblazer SS
Lowered, HID's, tinted.
06-11-2008, 12:07 PM #5
06-11-2008, 12:19 PM #6
If it is the MAF you could try tapping on it while the car is idling,,,,it may cause the car to stumble at idle, I've done this before.
Also here's another idea, not sure if this would work,,,,correct me if I'm wrong,,,,but if you suspect the MAF, can't you simply unplug it and force the car into speed density,,,,then drive the car and see if problem goes away????
If it's ignition related I would assume problem would still exist. No????
Just tossing a couple of ideas....
06-11-2008, 12:38 PM #7
- Jan 2006
yes if you unplug the maf..it goes into SD...but the car is sooo much rougher and a different car entirely ..but you are correct.
06-11-2008, 08:43 PM #8
Well read in another post that a guy changed his MAF sensor when his car would cut out at 2500 RPM. Today i unplugged it and i can tell there is a difference. There does not seem to be loss of power at 2500 RPM. So im pretty sure its the sensor. So is it not safe to run without it plugged in? Cause at the dealership the sensor is $287.00 WTF??
06-11-2008, 08:45 PM #9
Oh no mods or tune either. A member in posted in the Parts for sale section about a used MAF sensor so i looked it up and came to this conclusion
06-12-2008, 06:17 AM #10
- Jan 2006
yea its alright to run in SD...performance just isnt there
06-12-2008, 08:01 AM #11
06-12-2008, 08:04 AM #12
06-12-2008, 09:12 AM #13
06-12-2008, 11:38 AM #14
I'm not sure I'm leaps and bounds ahead,,,lol... I generally tune old stuff but I do tune my own 4th gen with HPtuner. I'm still a novice with a laptop but I have a very general idea how it works. Probably just enough to get me into trouble,,,
Thats why I threw out that idea about unplugging the MAF. Just my train of thought I guess
06-12-2008, 12:09 PM #15
I unplugged it and it runs fine and doesnt bog at 2500 RPMs. Is it safe to run with it unplugged?
06-12-2008, 01:17 PM #16
Hmmm,,,,I don't know for sure. That would be a question for Frost. You have basically forced the computer to run speed density,,,,which I believe uses the VE table for fuel calculations,,,,,the fuel is no longer tailored via MAF and changing conditions. Your mileage may suffer and who knows what other little things are affected.
I beleive the computers ability to do this is just to get you to your destination in the event of a failure...again I'm thinking out loud here Cars that run speed density all the time are custom tuned to do so...
It may or may not be safe but if it were me I would look into replacing the MAF as soon as possible.
06-12-2008, 03:44 PM #17
OK im goin to plug it back in right now lol
06-13-2008, 05:53 AM #18
- Jan 2006
we SD uses rpm, speed and temputure to fuel the car..it has no idea about how much incoming air there is..so you can see the problems right there..might run to rich or to lean...not worth it unless you get SD tuned
07-02-2008, 12:30 PM #19
Well just to let everyone know i found the problem. it was not the MAF sensor. There is a vacuum line which was connected to the PCV valve. Well this vacuum line was capped off with electrical tape. Previous owner FTW!! lol but i got a foot of 3/8 ID hose from autozone for $1.56 and now there is hesitation or anything. Yes!!
07-06-2008, 09:08 AM #20
- Sep 2005
- Omaha, Ne
Red- 1999 z28
I am having the same problem with my 99Z. When I get on the gas no matter the gear at around 2500-3500 RPM it hesitates for a second then its back to normal, it is so slight that the passenger does not even notice. It is only noticeable when you are driving it. The whole car does not buck or anything like that, very slight
I dont have the tape over the PCV hose problem either. I changed the fuel filter on it twice, thinking I got a bad one the first time or something...Could it be the oxygen sensors?? I had the codes read at my buddies shop and it came up with O2 sensors in previous codes, no codes currently...I do not really want to change them, because I am going to be doing a header install in the future sometime soon I hope. Is there some way that I can bypass this and rule it out? I don't really think it is a fuel problem, because it is not constant, just at that certain RPM rangeIt is not my daily driver, so I am in no rush, just saving the extra money up!! Mods are in signature, nothing big. Any other advice/suggestions would be helpful!!Red 1999 Camaro z28 M6
SLP LM1, SLP lid, K&N filter, Z06 Clutch, Pro 5.0 Shifter
Grotto Blue 1968 Chevelle SS396
375HP, .30 over, M21, comp cams .575/.604 solid, performer rpm intake, holly 770 street avenger, MSD pro billet distributer, blaster 2 coil, 6A Ignition, 3.73 gears, no hop bars
Help: 02 sensor bank 1 sensor 1-Is this drivers side or Passenger
By cballweg in forum General HelpReplies: 4Last Post: 01-15-2012, 10:44 AM -
Question: Reading trans temp stock sensor vs aftermarket sensor in pan
By senicalj4579 in forum Computer & TuningReplies: 1Last Post: 03-29-2011, 07:41 AM -
Knock Sensor/Oil Pressure Sensor Issue
By Slow '99 in forum External EngineReplies: 1Last Post: 04-04-2007, 08:28 AM
